土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ dvdrip、dvdscr、ts.tc版等的区别
发布于:2006-01-06 15:50:06 来自:站务休闲/闲聊茶吧 [复制转发]
看了N年的这些东西了,一直都没有机会发好的了解这些!今天看到了,不能错过!
CAM -
A cam is a theater rip usually done with a digital video camera. A mini tripod is sometimes used, but a lot of the time this wont be possible, so the camera make shake. Also seating placement isn’t always idle, and it might be filmed from an angle. If cropped properly, this is hard to tell unless there’s text on the screen, but a lot of times these are left with triangular borders on the top and bottom of the screen. Sound is taken from the onboard microphone of the camera, and especially in comedies, laughter can often be heard during the film. Due to these factors picture and sound quality are usually quite poor, but sometimes we’re lucky, and the theater will be fairly empty and a fairly clear signal will be heard.
CAM通常是用数码摄像机从电影院盗录。有时会使用小三角架,但大多数时候不可能使用,所以摄像机会抖动。同时由于放摄像机的座位并非总是空的,使得有时拍摄不是水平的。如果后期剪裁很好,这很难看出,除非屏幕下方有字幕。由
于声音是从摄像机自带的话筒录制,所以经常会录到观众的笑声等声音,尤其是喜剧片。因为这些因素,图象和声音质量通常都很差。但有时很幸运电影院相当空,这样会录到好一些的声音。
[separator]
TELESYNC (TS) -
A telesync is the same spec as a CAM except it uses an external audio source (most likely an audio jack in the chair for hard of hearing people). A direct audio source does not ensure a good quality audio source, as a lot of background noise can interfere. A lot of the times a telesync is filmed in an empty cinema or from the projection booth with a professional camera, giving a better picture quality. Quality ranges drastically, check the sample before downloading the full release. A high percentage of Telesyncs are CAMs that have been mislabeled.
除了使用外置的音源(一般是影院座椅上为听力不好的人设的耳机孔),TELESYSNC(TS) 和CAM的标准是相同的。这个直接的音源并不能保证是好的音源,这是它因为受到很多背景噪音的干扰。很多时候TS是在空的影院录制,或是用专业摄像机在投影室录制,所以图象质量可能比CAM好。质量的起伏可能很大,在下载前最好查看SAMPLE。很大比例的TS是从CAM错误标记成。
TELECINE (TC) -
A telecine machine copies the film digitally from the reels. Sound and picture should be very good, but due to the equipment involved and cost telecines are fairly uncommon. Generally the film will be in
correct aspect ratio, although 4:3 telecines have existed. A great example is the JURASSIC PARK 3 TC done last year. TC should not be confused with TimeCode , which is a visible counter on screen throughout the film.
TELECINE (TC) 使用电视电影机从胶片直接数字拷贝,其图象和声音质量应该很好。但由于使用的设备和费用很高,TC很少见。通常会使用正确的高宽比,但有时也有4:3的TC。去年的侏罗纪公园III是一个很好的例子。不应将TC和TimeCode(时间码)混淆,时间码是一个在屏幕上可见的计数器。
SCREENER (SCR) -
A pre VHS tape, sent to rental stores, and various other places for promotional use. A screener is supplied on a VHS tape, and is usually in a 4:3 (full screen) a/r, although letterboxed screeners are sometimes found. The main draw back is a "ticker" (a message that scrolls past at the bottom of the screen, with the copyright and anti-copy telephone number). Also, if the tape contains any serial numbers, or any other markings that could lead to the source of the tape, these will have to be blocked, usually with a black mark over the section. This is sometimes only for a few seconds, but unfortunately on some copies this will last for the entire film, and some can be quite big. Depending on the equipment used, screener quality can range from excellent if done from a MASTER copy, to very poor if done on an old VHS recorder thru poor capture equipment on a copied tape. Most screeners are transferred to VCD, but a few attempts at SVCD have occurred, some looking better than others.
SCREENER(SCR)是在电影发行VHS录象带之前送到录象出租店及其他地方用做促销目的。SCREENER使用VHS录象带,通常使用4:3(全屏)的高宽比,但有时也会有LETTERBOXED(1.85:1宽银幕) SCREENER. 主要的缺点是有“TICKER”(在屏幕下
方滚动的消息,包含版权和反盗版电话号码)。同时,如果录象带包含任何序列号或可以导致查出录象带来源的记号,这些记号必须被遮掉,通常使用一个黑斑遮住上述部位。有时这些记号只出现几秒钟,有时也可能不幸在怎个电影中出现,而且有时会很大。根据使用的设备,SCREENER的质量可能是极好,如果是从原版拷贝;也可能很差,如果是从翻录的拷贝录制,同时又使用很烂的捕捉设备和录象机。大多数的SCREENER被转制成VCD,现在也出现了SVCD;有些看起来比
另一些好。
全部回复(4 )
  • dk401
    dk401 沙发
    ASPECT RATIO TAGS -
    These are *WS* for widescreen (letterbox) and *FS* for Fullscreen.
    *ws*表示宽银幕,*FS*表示全屏幕。
    RECODE -
    A recode is a previously released version, usually filtered through TMPGenc to remove subtitles, fix color etc. Whilst they can look better, its not looked upon highly as groups are expected to obtain their own sources.
    RECODE是以前已经发布过的版本,通常用TMPGenc编码过滤以去除字幕,纠正颜色等。虽然它们看起来好一些,但通常不认为这是好的行为因为发布组织应该去找他们自己的片源。
    REPACK -
    If a group releases a bad rip, they will release a Repack which will fix the problems.
    如果发布组织发布了一个坏的版本,他们会发布REPACK来解决这些问题。
    NUKED -
    A film can be nuked for various reasons. Individual sites will nuke for breaking their rules (such as "No Telesyncs") but if the film has something extremely wrong with it (no soundtrack for 20mins, CD2 is incorrect film/game etc) then a global nuke will occur, and people trading it across sites will lose their credits. Nuked films can still reach other sources such as p2p/usenet, but its a good idea to check why it was nuked first in case. If a group realise there is something wrong, they can request a nuke.
    一个发布可能因为多种原因被NUKE掉。有些网站会因为违犯他们的规则而NUKE发布(比如不允许发布TS版本)。但如果发布的版本有很大的问题(如20分钟没有声音,CD2是错误的电影或游戏),那么所有的网站都会NUKE这个发布。在这些网站上交换N UKED版本的人会失掉他们的信誉。但NUKED发布仍然可以通过P2P/USENET传播,所以应该总是首先找到其被NUKE的原因以防万一。如果发布组织发觉他们的发布有问题,他们可以要求NUKE。
    NUKE REASONS :: this is a list of common reasons a film can be nuked for (generally DVDRip)
    常见的NUKE原因(通常是DVDRIP):
    ** BAD A/R ** :: bad aspect ratio, ie people appear too fat/thin
    错误的高宽比,即画面太胖或太瘦。
    ** BAD IVTC ** :: bad inverse telecine. process of converting framerates was incorrect.
    错误的反转电视电影TC。转换祯频不对。
    ** INTERLACED ** :: black lines on movement as the field order is incorrect.
    移动的黑线,由于field order不正确。
    DUPE -
    Dupe is quite simply, if something exists already, then theres no reason for it to exist again without proper reason.
    DUPE很简单。如果某个电影发布已有,那么没有合适的理由就不因该允许它的存在。
    2006-01-06 15:54:06
  • dk401
    dk401 板凳
    SUBBED -
    In the case of a VCD, if a release is subbed, it usually means it has hard encoded subtitles burnt throughout the movie. These are generally in malaysian/chinese/thai etc, and sometimes there are two different languages, which can take up quite a large amount of the screen. SVCD supports switch able subtitles, so some DVDRips are released with switch able subs. This will be mentioned in the NFO file if included.
    对于VCD发布而言,SUBBED通常表示字幕被压进了电影。它们通常是马来语/中文/泰文等,有时有两种语言。它们可能占据了很大一部分屏幕。SVCD支持外挂字幕,所以DVDRip用外挂字幕发布。这些信息可以在NFO文件中找到。
    UNSUBBED -
    When a film has had a subbed release in the past, an Unsubbed release may be released
    当一部电影曾经发布过有字幕的SUBBED版本,没字幕的UNSUBBED版本也可能发布。
    LIMITED -
    A limited movie means it has had a limited theater run, generally opening in less than 250 theaters, generally smaller films (such as art house films) are released as limited.
    LIMITED电影指该电影只在有限的电影院放映,通常少于250家。通常较小的电影(比如艺术电影)的发行是LIMETED。
    INTERNAL -
    An internal release is done for several reasons. Classic DVD groups do a lot of .INTERNAL. releases, as they wont be dupe’d on it. Also lower quality theater rips are done INTERNAL so not to lower the reputation of the group, or due to the amount of rips done already. An INTERNAL release is available as normal on the groups affiliate sites, but they can’t be traded to other sites without request from the site ops. Some INTERNAL releases still trickle down to IRC/Newsgroups, it usually depends on the title and the popularity. Earlier in the year people referred to Centropy going "internal". This meant the group were only releasing the movies to their members and site ops. This is in a different context to the usual definition.
    INTERNAL发布有几个原因。经典的DVD组织有很多.INTERNAL.发布版本,这样不会引起混淆。同时,低质量的发布会加以INTERNAL标记,这样不会降低发布组织的声誉,或由于已经发布的数量。INTERNAL发布可以正常的在组织的会员网站上获取,但没有其他网站管理员的要求它们不可以被交换到其他网站。一些TERNAL发布仍然流到IRC/NEWSGROUP,这通常取决于电影及其流行度。今年早些时候,人们把CENTROPY做为INTERNAL。这表示发布组织只向其会员和网站管理员发布。这和其通常意思不同。
    STV -
    Straight To Video. Was never released in theaters, and therefore a lot of sites do not allow these.
    STV表示电影从未在电影院放映过就被发布,因此很多望网站不允许STV。
    2006-01-06 15:53:06
闲聊茶吧
114.52 万条内容 · 201 人订阅
春节晚会预审纪实(ZT)
---刚刚看到,真不敢相信啊--- “说吧,你是谁的托儿?”坐在记者后排的中年男人凑了上来低声说,“你给我们的节目叫好,我也给你的叫好,大家互相帮忙,争取都能上春晚。”  2005年12月31日下午3时,是2006年中央电视台春节联欢晚会语言类节目第四次审查正式开始的时间。还差10分钟到3点,央视800平方米演播室里突然哄闹起来,一群观众鱼贯而入,很快在没有座位号的观众席上,各自找到自己的位置并安静下来。后排的那五六个中年男人,来得稍微晚了一点,发现中间位置已经被坐满了,只能坐在最后一排。
