土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ 结构设计箴言
结构设计箴言
发布于:2010-09-08 09:09:08 来自:站务休闲/闲聊茶吧 [复制转发]
Structural engineering is the art of using materials that have properties which can only be estimated
To build real structures that can only be approximately analyzed
To withstand forces that are not accurately known
So that our responsibilities with respect to public safety is satisfied
do not use a structural analysis program unless you fully understand the theory and approximation used within the program
do not creat a computer model until the loading; material properties and boundary condition are clearly defined
全部回复(16 )
  • terryks
    terryks 沙发
    有些道理!!
    2011-01-10 14:04:10
  • flashsnow
    flashsnow 板凳
    不能完全领会箴言的精神,高手给翻译一下
    2011-01-03 11:56:03
闲聊茶吧
114.52 万条内容 · 201 人订阅
藏在书包里的玫瑰
青少年的成长历程
