acceptable quality:合格质量
acceptance lot:验收批量
aciera:钢材
admixture:外加剂
against slip coefficient between friction surface of high-strength bolted connection:高强度螺栓摩擦面抗滑移系数
aggregate:骨料
air content:含气量
air-dried timber:气干材
allowable ratio of height to sectional thickness of masonry wall or column:砌体墙、柱容许高厚比
allowable slenderness ratio of steel member:钢构件容许长细比
allowable slenderness ratio of timber compression member:受压木构件容许长细比
allowable stress range of fatigue:疲劳容许应力幅
allowable ultimate tensile strain of reinforcement:钢筋拉应变限值
allowable value of crack width:裂缝宽度容许值
allowable value of deflection of structural member:构件挠度容许值
allowable value of deflection of timber bending member:受弯木构件挠度容许值
allowable value of deformation of steel member:钢构件变形容许值
allowable value of deformation of structural member:构件变形容许值
allowable value of drift angle of earthquake resistant structure:抗震结构层间位移角限值
amplified coefficient of eccentricity:偏心距增大系数
anchorage:锚具
anchorage length of steel bar:钢筋锚固长度
approval analysis during construction stage:施工阶段验算
arch:拱
arch with tie rod:拉捍拱
arch—shaped roof truss:拱形屋架
area of shear plane:剪面面积
area of transformed section:换算截面面积
aseismic design:建筑抗震设计
assembled monolithic concrete structure:装配整体式混凝土结构
automatic welding:自动焊接
auxiliary steel bar:架立钢筋
全部回复(15 )
只看楼主 我来说两句回复 举报
