土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 建筑结构中英文翻译
建筑结构中英文翻译
发布于:2005-12-26 18:32:26 来自:注册考试/注册土木工程师 [复制转发]
建筑结构中英文翻译
非原创,供大家参考:
A
acceptable quality:合格质量
acceptance lot:验收批量
aciera:钢材
admixture:外加剂
against slip coefficient between friction surface of high-strength bolted connection:高强度螺栓摩擦面抗滑移系数
aggregate:骨料
air content:含气量
air-dried timber:气干材
allowable ratio of height to sectional thickness of masonry wall or column:砌体墙、柱容许高厚比
allowable slenderness ratio of steel member:钢构件容许长细比
allowable slenderness ratio of timber compression member:受压木构件容许长细比
allowable stress range of fatigue:疲劳容许应力幅
allowable ultimate tensile strain of reinforcement:钢筋拉应变限值
allowable value of crack width:裂缝宽度容许值
allowable value of deflection of structural member:构件挠度容许值
allowable value of deflection of timber bending member:受弯木构件挠度容许值
allowable value of deformation of steel member:钢构件变形容许值
allowable value of deformation of structural member:构件变形容许值
allowable value of drift angle of earthquake resistant structure:抗震结构层间位移角限值
amplified coefficient of eccentricity:偏心距增大系数
anchorage:锚具
anchorage length of steel bar:钢筋锚固长度
approval analysis during construction stage:施工阶段验算
arch:拱
arch with tie rod:拉捍拱
arch—shaped roof truss:拱形屋架
area of shear plane:剪面面积
area of transformed section:换算截面面积
aseismic design:建筑抗震设计
assembled monolithic concrete structure:装配整体式混凝土结构
automatic welding:自动焊接
auxiliary steel bar:架立钢筋
B
backfilling plate:垫板
balanced depth of compression zone:界限受压区高度
balanced eccentricity:界限偏心距
bar splice:钢筋接头
bark pocket:夹皮
batten plate:缀板
beam:次梁
bearing plane of notch:齿承压面(67)
bearing plate:支承板(52)
bearing stiffener:支承加劲肋(52)
bent-up steel bar:弯起钢筋(35)
block:砌块(43)
block masonry:砌块砌体(44)
block masonry structure:砌块砌体结构(41)
blow hole:气孔(62)
board:板材(65)
bolt:螺栓(54)
bolted connection:(钢结构)螺栓连接(59)
bolted joint:(木结构)螺栓连接(69)
bolted steel structure:螺栓连接钢结构(50)
bonded prestressed concrete structure:有粘结预应力混凝土结构(24)
bow:顺弯(71)
brake member:制动构件(7)
breadth of wall between windows:窗间墙宽度(46)
brick masonry:砖砌体(44)
brick masonry column:砖砌体柱(42)
brick masonry structure:砖砌体结构(41)
brick masonry wall:砖砌体墙(42)
broad—leaved wood:阔叶树材(65)
building structural materials:建筑结构材料(17)
building structural unit:建筑结构单元(
building structure:建筑结构(2
built—up steel column:格构式钢柱(51
bundled tube structure:成束筒结构(3
burn—through:烧穿(62
butt connection:对接(59
butt joint:对接(70)
butt weld:对接焊缝(60)
全部回复(15 )
  • workchy
    workchy 沙发
    好书,谢谢楼主.
    2010-10-20 22:24:20
  • workchy
    workchy 板凳
    好书,谢谢楼主
    2010-10-20 21:58:20
注册土木工程师
6.76 万条内容 · 269 人订阅
哪位有关于水方面或环保方面的英语文章啊~
哪位有关于水方面或环保方面的英语文章啊~!跪谢了~!谢谢各位大虾啦~!
