土木在线论坛 \ 建筑结构 \ ETABS \ Etabs中Pushover分析配筋有影响吗
Midas分析中在Pushover分析前需设计配筋,在Etabs中Pushover分析中,不需配筋计算也可以进行分析,是否没考虑配筋多少的影响?
全部回答(10 )
  • haohanyanshou
    这是很好的资料,我也下来看看,有时间就学习下,不错。
    2016-12-15 09:59:15 来自 PC 评论 举报
  • shenakippei
    In sap, there is rebar define in the frame section. You could define the top and bottom rebars for beam type frame section and the longitude rebar for column type frame section. SAP will calculation the yield moment based on the defined rebar of the frame sections. The plastic hinge is defined with these yield moment according to FEMA 356.
    2010-08-29 16:14:29 来自 PC 评论 举报
ETABS
1.67 万条内容 · 53 人订阅
