土木在线论坛 \ 施工技术 \ 工地图片 \ Boron removal from seawater reverse osmosis permeate
发布于:2010-06-22 13:41:22 来自:施工技术/工地图片 [复制转发]
Boron removal from seawater reverse osmosis permeate utilizing selective ion exchange resin
Abstract
A minimum of boron in irrigation water is required for certain metabolic activities, but if its concentration is
only slightly higher, plant growth will exhibit effects of boron poisoning, which are yellowish spots on the leaves
and fruits, accelerated decay and ultimately plant expiration. Seawater in general contains relatively high
concentration of boron: 4 to 5 ppm. The Red Sea water utilized as feed for the Eilat desalination plant contains
4.7 ppm boron falling within the above range. When acidified as a part of pre-treatment, the boron is in the form
of boric acid, manifesting poor trans-membrane rejection of 65%. In the Eilat desalination plant the result has
been 1.8 ppm of boron concentration in the permeate, a level by far higher than the allowance of the standards. A
process based on the selective removal of boron with resin has been evolved. The pilot plant tests allowed an
accurate cost assessment for the removal of boron in the range of 4 to 6 US cents per cubic meter of permeate,
dependent on the cost of the resin, the chemicals, and the operation and maintenance.
Keywords: Boron; Selective ion exchange resin
工地图片
50.2 万条内容 · 383 人订阅
请问空调管道的保温可以这样包吗?
采用这种材料的话,其结口处是否还应采用铝泊锡纸张贴?目前现场没有张贴,到处出现冷凝水。请高手支招,施工规范上是否有相关要求?
