土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ 到了国外才发现这些单词也很重要~特别是女生额
发布于:2010-06-16 19:47:16 来自:站务休闲/闲聊茶吧 [复制转发]
今天去SEPHORA想去买化妆品,但是进了那里才发现那些个什么隔离霜啊,唇彩啊用英语都不回,补习补习~~哈哈
一,化妆品/护肤品/洗涤
护肤: skin care
洗面奶: facial cleanser/face wash(foaming,milky,cream,gel)
爽肤水: toner/astringent
紧肤水:firming lotion
柔肤水:toner/smoothing toner (facial mist/facial spray/complexion mist)
护肤霜: moisturizers and creams
保湿:moisturizer
隔离霜,防晒:sun screen/sun block
美白:whitening
露:lotion,霜:cream
日霜:day cream
晚霜:night cream
眼部gel: eye gel
面膜: facial mask/masque
眼膜: eye mask
护唇用:lip care
口红护膜:lip coat
磨砂膏: facial scrub
去黑头: (deep) pore cleanser/striper pore refining
去死皮: exfoliating scrub
润肤露(香体乳):lotion/moisturizer
护手霜: hand lotion/moisturizer
沐浴露: wash
二,化妆品/护肤品功能
acne/spot(青春痘用品)
active(赋活用)
after sun(日晒后用品)
alcohol-free(无酒精)
anti-(抗、防)
anti-wrinkle(抗老防皱)
balancing(平衡酸硷)
clean-/purify-(清洁用)
combination(混合性皮肤)
dry(干性皮肤)
essence(精华液)
facial(脸部用)
fast/quick dry(快干)
firm(紧肤)
foam(泡沫)
gentle(温和的)
hydra-(保湿用)
long lasting(持久性)
milk(乳)
mult-(多元)
normal(中性皮肤)
nutritious(滋养)
oil-control(抑制油脂)
oily(油性皮肤)
pack(剥撕式面膜)
peeling(敷面剥落式面膜)
remover(去除、卸妆)
repair(修护)
revitalite(活化)
scrub(磨砂式(去角质))
sensitive(敏感性皮肤)
solvent(溶解)
sun block(防晒用)
toning lotion(化妆水)
trentment(修护)
wash(洗)
waterproof(防水)
三,化妆品/彩妆
彩妆: cosmetics
遮瑕膏: concealer
修容饼:shading powder
粉底: foundation (compact,stick)
粉饼: pressed powder
散粉:loose powder
闪粉:shimmering powder/glitter
眉粉: brow powder
眉笔:brow pencil
眼线液(眼线笔):liquid eye liner, eye liner
眼影: eye shadow
睫毛膏: mascara
唇线笔: lip liner
唇膏: lip color/lipstick(笔状 lip pencil,膏状 lip lipstick,盒装 lip color/lip gloss)
唇彩: lip gloss/lip color
腮红: blush
卸装水: makeup remover
卸装乳: makeup removing lotion
帖在身上的小亮片: art
指甲: manicure/pedicure
指甲油: nail polish/color/enamel
去甲油:nail polish remover
护甲液:nail saver
发: hair products/accessories
洗发水: shampoo
护发素: hair conditioner
锔油膏: conditioning hairdressing/hairdressing gel /treatment
摩丝: mousse
发胶: styling gel
染发: hair color
冷烫水: perm/perming formula
卷发器: rollers/perm rollers
四,化妆品/化妆工具
工具: cosmetic applicators/accessories
粉刷: cosmetic brush, face brush
粉扑: powder puffs
海绵扑: sponge puffs
眉刷: brow brush
睫毛夹: lash curler
眼影刷: eye shadow brush/shadow applicator
口红刷: lip brush
胭脂扫: blush brush
转笔刀: pencil sharpener
电动剃毛器: electric shaver-for women
电动睫毛卷: electric lash curler
描眉卡: brow template
纸巾: facial tissue
吸油纸: oil-absorbing sheets
化装棉: cotton pads
棉签: q-tips
  1、eye cream/eye care/eye gel:眼霜或者眼部保养品或者眼胶
  2、masque:面膜,是面膜产品的通称.
  面膜的其他表示方法有*mask-面具*pack-外盒,包
  3、day&night:指白天专用的产品和晚上专用的产品
  4、exfoliate:剥落,脱落.一般看到exfoliate基本上就是去角质的产品了.
  其他表示方法:scrub去除杂质
  5、essence:精华,要素;指精华液,美容液,精华露.
  essential-精华的;soul-精髓;extract-萃取精华
  6、lotion:化妆水,洗涤剂.英文法文表示一致,都是lotion
  有些品牌也用lotion作为乳液的用词,不过严格来讲,最好是在lotion前面加上milk(乳液,乳状物),或者milky(乳状的),也就是milk/milky lotion
  化妆水的其他用语:toner;tonic;water
  乳液的其他用语:fluid-流动的,液体(英文法文通用);liquid-液体物质
  7、foam:泡沫,或者可以挤出来的泡沫,可以产生泡沫的产品
  8、soap:肥皂,块状的产品
  肥皂类其他用语:bar
  9、make up remover:卸妆
  卸妆的其他用语:cleanser, cleansing, clean off, clean out都有清洁,扫除的意思,但有时会跟洗脸产品的标示有重叠,要留意是否注明[可以清除彩妆]
  10、balm:香油,芳香性树脂,大多指护唇油(罐装的唇膏)
  护唇膏的其他用语:lipsalve-嘴唇用油膏;lip ointment-唇用软膏
  11、shake well before use:使用前请先摇匀
  通常这一类产品都含有不同密度的物质,所以要先摇匀
  摇匀的其他用语:brandish-摇动;jiggle-轻轻晃动;joggle-轻摇
  12、tissue-off:用完以后要以面纸或者化妆棉,擦掉的产品
  擦拭的其他用语:well-off;brush;wipe off
  需要[剥,撕]的其他用语eel off
  13、wash-off:水洗,用后要洗掉的
  水洗的其他用语:water-off;rinsing-off;washable;sweep
  14、pat:轻拍,轻抚,轻压
  拍打的其他用语ab-以手按压;flap-拍打,扑打
  有些产品需要稍加画圆,按摩.外文是:massage-onto-在肌肤上面按摩;circular movement-画圆移动
nail polish 指甲油
cosmetics case 化妆箱
high heels 高跟鞋
gloves 手套
wrist watch 手表
belt 腰带
pendant 项饰
necklace 项链
neck scarf 围巾
earrings 耳环
bracelet 手链, 手镯
tie 领带
cuff links 袖扣
ascot 宽领带
pocket watch 表袋
hair net 发网
shampoo 洗发水
cream rinse 营养发水
hair spray 发胶
powder puff 粉扑
compact 带镜粉盒
astringent 化妆水
perfume 香水
skin milk 乳液
cold cream 油底霜
atomizer 喷雾式香水
clip 夹子
hand mirror 手镜
bobby pin 发夹
false eyelash 假睫毛
lipstick 口红
wig 假发
tie pin 领带夹
tissue 面纸
purse 手提包
brooch 胸针
shawl 披肩
neckerchief 领巾
还有,来例假是:I'm having my period吼吼~~~
Because I have pimples 痘痘in the face.
毛孔:pore
T型区:T-zone or T area
闲聊茶吧
114.52 万条内容 · 201 人订阅
中国人正在上的四大当,你上了几个了?
中国人正在上的四大当,你上了几个了?——中国香港著名经济学家郎咸平第一大当:买房   买房意味着什么?意味着你拥有了一个属于自己的房子。是的,你是这样以为,但是在中国你并无法拥有这个房子,只是租给你而已。因为房子是你的,地不是你的,只是把土地使用权70年(从现在退70年那是抗日战争时期,谁见过那时候的房子?)。房子通常情况下30年左右就会遇上拆迁或者旧房改造。也就是说你花了买房的钱,却只能得到租房的实际效果。当然这还不是最坏的。最坏的是,当几十年后你发觉上当了!有一群流氓冲进你用一辈子积蓄买下的房子,画上一个大大的拆字!然后把你的家当全部当垃圾一样的仍出门外,不顾你的苦苦哀求,甚至还在报纸上给你按一个钉子户的臭名,任大众辱骂的时候你就会知道什么叫做绝望!
