土木在线论坛 \ 电气工程 \ 变压器 \ 变压器器问题
变压器器问题
发布于:2010-06-06 11:13:06 来自:电气工程/变压器 [复制转发]
power transformer enlisted MT and BT copper coil, cooling in oil, conforming to IEC recommendations, consistent with the standards NFC 52-100, 52-112, 52-113,
adjusting the voltage switch-off,
frequency 50Hz
MT and BT crossed china conforming to NFC 52-052, 52-053,
Short circuit voltage 4%
Pole Type H.61
Power 160 KVA
HV 20000 volts
BT B2 (voltage between phase 100V Vacuum)
coupling: Neutral left side low voltage
-breaker pole top transformer type H.61
consistent with spéecification HN 63-S-10
with mechanical, (November-December pole m)
with block trigger
Type 160kva/B2
-transformer support bracket-type H61
galvanized steel with horizontal cross
有谁知道什么是MT and BT j铜线圈吗?
NFC 标准跟IEC有区别吗?
Pole Type H.61 是什么意思啊?
在这里感谢先了。。
  • clw123456
    clw123456 沙发
    对不起了,我对英文也是外行呀?无奈!!!!!!!!!!!!!!
    2010-06-06 21:17:06
变压器
14.15 万条内容 · 436 人订阅
电流互感器电流差接线方式
电流互感器差接线的接线方式没看懂,请大家指教。
