土木在线论坛 \ 建筑结构 \ MIDAS \ midas连续刚构桥模型的运行错误
midas连续刚构桥模型的运行错误
发布于:2010-06-06 09:59:06 来自:建筑结构/MIDAS [复制转发]
MULTI-FRONTAL SOLVER
AVAILABLE MEMORY = 894.6 MBytes
CONSTRUCTION STEP NO. : 1 / 14 STAGE NO : 1 STEP NO : 1
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ELEMENT NO. : 784 OF 784
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 1
MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 10 % .
WARNING : NODE NO. 463 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2211
WARNING : NODE NO. 58 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 6
WARNING : NODE NO. 467 RZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2238
WARNING : NODE NO. 467 RX DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2236
WARNING : NODE NO. 467 DZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2235
WARNING : NODE NO. 467 DY DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2234
WARNING : NODE NO. 467 RX DOF MAY BE SINGULAR.
WARNING : NODE NO. 68 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 38
WARNING : NODE NO. 68 RX DOF MAY BE SINGULAR.
MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 20 % .
WARNING : NODE NO. 63 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 21
WARNING : NODE NO. 464 RZ DOF MAY BE SINGULAR.
MULTI-FRONTAL SOLUTION HAS BEEN COMPLETED.
DISPLACEMENT/FORCE/STRESS OUTPUT.
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 2
DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
ELEM. : 784 OF 784
CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
CONSTRUCTION STEP NO. : 2 / 14 STAGE NO : 1 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 3
ELEM. : 784 OF 784
CONSTRUCTION STEP NO. : 3 / 14 STAGE NO : 2 STEP NO : 1
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
WARNING : NODE NO. 48 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 278
WARNING : NODE NO. 48 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 282
WARNING : NODE NO. 468 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2576
WARNING : NODE NO. 468 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2578
WARNING : EQUATION NO. 374
WARNING : NODE NO. 59 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 348
WARNING : NODE NO. 10 RZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 60
WARNING : NODE NO. 10 RX DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 58
WARNING : NODE NO. 10 DY DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 56
WARNING : NODE NO. 10 RX DOF MAY BE SINGULAR.
WARNING : NODE NO. 10 RZ DOF MAY BE SINGULAR.
WARNING : NODE NO. 10 DX DOF MAY BE SINGULAR.
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.26854E-01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.12585E-01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 4
DISPLACEMENT ERROR NORM .. : 0.15444E-22 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
CONSTRUCTION STEP NO. : 4 / 14 STAGE NO : 2 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.65851E+48 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : Infinity CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 5
DISPLACEMENT ERROR NORM .. : NaN CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 6
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 7
好像是结果验证错误,怎么修改啊?请高手帮忙
全部回复(22 )
  • lc546517093
    lc546517093 沙发
    您好 你帖子上说的这个问题是怎么解决的?我也碰到这这样的问题 想请教一下 谢谢
    2014-04-18 23:38:18
  • mige0939
    mige0939 板凳
    检查约束,应该是那个问题,看看那几个节点的约束,以及整个模型的受力,可以解决,我也碰到过这个问题
    2011-03-07 09:43:07
MIDAS
5.84 万条内容 · 317 人订阅
midas预应力筋的两类错误
用Midas civil 6.7.1做了一个连续钢构桥模型,运行后预应力筋出现了两类错误1、预应力钢束()的位置和预应力钢束分配的单元位置不一致2、预应力钢束()没有张拉,刚学会用这个软件,也不会修改,不知道哪位高手能帮忙解答一下,怎么修改,毕业设计已到关键时刻,小弟已到生死存亡时刻。不胜感激!
