土木在线论坛 \ 电气工程 \ 输变电工程 \ IEC62271-1:2007 High-voltage switchgear and controlgear-Part 1
发布于:2010-05-18 14:22:18 来自:电气工程/输变电工程 [复制转发]
High-voltage switchgear and controlgear-Part 1 Common specifications
This part of IEC 62271 applies to a.c. switchgear and controlgear designed for indoor and
outdoor installation and for operation at service frequencies up to and including 60 Hz on
systems having voltages above 1 000 V.
This standard applies to all high-voltage switchgear and controlgear except as otherwise
specified in the relevant IEC standards for the particular type of switchgear and controlgear.
NOTE For the use of this standard, high voltage (see IEV 601-01-27) is the rated voltage above 1 000 V.
However, the term medium voltage (see IEV 601-01-28) is commonly used for distribution systems with voltages
above 1 kV and generally applied up to and including 52 kV.
全部回复(12 )
  • hyl009
    hyl009 沙发
    有没有中文版的啊
    2016-03-17 16:11:17
  • ymwatcher
    ymwatcher 板凳
    好资料,谢谢分享,楼主加油。。。
    2016-03-14 17:49:14
输变电工程
11.1 万条内容 · 662 人订阅
IEC62271-3:2006 High-voltage switchgear and controlgear-part3
Part3:Digital interfaces based on IEC 61850This standard is a product family standard for high-voltage switchgear and controlgear andassemblies thereof. It provides an application of the horizontal standard series IEC 61850
