土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 英文文章,没见过吧
英文文章,没见过吧
发布于:2010-05-04 17:46:04 来自:建筑结构/混凝土结构 [复制转发]
Timing is Everything
The best-laid plans of mice and men and all that, but, as much as possible, you should plan your schedule for the day before you set off. The last thing you want is to be doubling back on yourself when,wholesale
jerseys
, if you had looked to the jobs ahead you could have cut your delivery times in half. By air force 1 shoes
their very nature, courier jobs will have you travelling all over the country and sometimes you can feel like you are chasing your own tail. But with a little forward-thinking you can economise not only your time, but also fuel as well. Many drivers today are part of a freight exchange where they can match courier jobs with locations and ensure they are not returning from a destination with an empty van.
Fuel Up
This means both you and your van. It can be all too tempting to push on to try and get as many courier jobs done as possible; but it is imperative that you eat and rest sensibly whilst on Ultra Tall Ugg Boots the road, so you will need to take regular breaks when driving long distances. While it's not always practical (or economical) to stop for a three course lunch on the
discount jerseys,road, do factor in some down time during the day to refresh and refuel.
There's No Place like Home
So, after eight or ten hours on the road, it's time to head home. After one last check on your schedule and the back of your van, the day is over save for the drive home. Don't forget to pick up a bunch of flowers from the garage for the wife and perhaps something special for dessert, then park up, ugg boots and pat your van good night. But your day's not quite over yet; you will probably need to spend a couple of hours going through your invoices, bills and planning the schedule for tomorrow's courier jobs before calling it a day.
Working doing courier jobs is not everybody's idea of the ideal job; but if you're looking for jordan sneakers freedom, adventure and discount jerseys, the open road, they just may be for you...
全部回复(6 )
  • zhangdaqian1910
    楼主发错地方了吧??
    2010-05-18 19:01:18
  • hellonetyyy
    hellonetyyy 板凳
    呵呵,同感受
    2010-05-15 23:20:15
140.17 万条内容 · 2232 人订阅
MIDAS Civil 学习资料
MIDAS Civil 学习资料: 1、 2006MIDAS上海培训交流会; 2、20080817; 3、10_叠联合截面施工阶段分析方法(针对用户定义截面);4、_25+35+25连续梁板单元分析;5、_midas设计示例验算说明;6、_T梁梁格;7、_T梁梁格2; 8、_钢结构建模动画;9、_先简支后连续;10、斜板施工阶段板梁实体混合模型;11、_预应力混凝土箱梁的分析与设计.part1;12、_预应力混凝土箱梁的分析与设计.part2;13、预应力混凝土箱梁的分析与设计.part3;14、开口部详细;·15、例1悬臂梁和简支梁;16、例2梁单元、板单元及实体单元悬臂梁;17、例3-反应谱分析;18、例4-预应力混凝土梁的分析;19、例题2厂房.part1;20、例题2厂房.part2
