土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 请教江苏地区填充墙都是采用什么墙体的
请教江苏地区填充墙都是采用什么墙体的
发布于:2010-04-30 15:06:30 来自:建筑结构/混凝土结构 [复制转发]
如题,请教各位知情者!
江苏地区填充墙都是采用什么墙体的,一般做多厚?
全部回复(7 )
  • zhycht
    zhycht 沙发
    煤矸石空心砌块
    2010-05-13 19:39:13
  • bxzyh
    bxzyh 板凳
    再问下,200厚的墙体,梁一般做多宽呢?如果按一般做法250的话,便会有更多地方都会露出梁线条了
    2010-05-13 14:10:13
140.17 万条内容 · 2231 人订阅
美国标准是怎样确定地基承载力的?
小弟现在正在做一个国外建筑的设计,但是地勘报告做了标准贯入度的实验 三轴有(无)排水的试验,给了很多试验数据,但是没有给土的承载力数值,他们的贯入度实验是这样描述的:The Standard Penetration Test (SPT) was carried out according the ASTM D1586 (1974). The blow count of the SPT was observed for 6 successive drives of sampler spoon to a penetration each of 75mm. or to a maximum of 30 blows whichever happens first. The first two drives are considered as seating drive. The number of blows for the next 4 drives is considered as the Penetration Resistance (N). A value of 30 blows per 75mm. is considered as refusal. In case the N- value reaches 60 without achieving 300mm. penetration, the SPT was stopped to avoid damaging the SPT spoon and to
