土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 一些建筑
一些建筑
发布于:2010-04-23 15:14:23 来自:建筑设计/公共建筑设计 [复制转发]
所 在 地:巴西 圣保罗
总面积:890平方米
建筑面积:995平方米
Site Area: 890 m2
Built Area: 995 m2
巴西建筑师Marcio Kogan近期完成了他在巴西圣保罗设计的6号住宅。
Brazilian architect Marcio Kogan has recently completed the House 6 project in São Paulo, Brazil.
>> 浏览全部 33 张图片
蒙圣伊莱尔别墅
2010-4-23
所 在 地:加拿大 魁北克
加拿大Blouin Tardif建筑事务所设计了这座位于加拿大魁北克的蒙圣伊莱尔别墅。
Canadian architects Blouin Tardif Architecture have designed a home in Mont-Saint-Hilaire, Quebec.
>> 浏览全部 14 张图片
明知大学Bangmok图书馆
2010-4-23
所 在 地:韩国 首尔
这座有着轻微弧形造型的大厦,旨在欢迎明知大学的学生团体们,并且尽量保持与周边居住区和其他大学设施的相互和谐。这座大厦最后被用来作为大学的图书馆投入使用。曲线形的外立面利用U型玻璃,U型玻璃不能够直接反射光,但是可以过滤日光,使得室内光线温暖舒适。
The massing started off with gently curved form which seeks to welcome the student body of Myongji University and harmonizes in its surrounding of residential area and other university facilities. The square mass was subsequently inserted to serve as the functional zones to contain the books. The curvilinear outer skin comes to life with U-GLASS, and the square mass is expressed with wood (IPE) that relates to the nature off books, paper, and bookshelves. U-Glass doesn’t directly reflect light, but filters light to create a warm and comfortable ambience; wood ages, similar to books, and archives the flow of time in its materiality.
>> 浏览全部 23 张图片
Benetton托儿所
2010-4-23
所 在 地:意大利 特雷维索 Ponzano Veneto
面积:1868平方米
年限:2006
施工:2007
Project Area: 1,868 sqm
Project Year: 2006
Construction Year: 2007
设计师构建了一个大的正方体,里面包含了九个小正方体。中央正方体从视觉高度上凸出,保证了自然光的采用。教室被安排在周边。
这个正方体结构被一个巨大的,环形的,双层环墙体包裹,向天空开放,庭院按照建议创建四个元素:空气,土地,火以及水。
We built a square box composed of nine smaller squares. The center square emerges to bring light from the heights of the vestibule. The classrooms are arranged in the surrounding squares.
This square structure is inscribed within a larger, circular enclosure made up of double circular walls. Open to the sky, four courtyards are created that suggest the four elements: air, earth, fire and water.
>> 浏览全部 22 张图片
悬臂住宅
2010-4-22
所 在 地:美国 华盛顿 花岗岩瀑布
面积:2800平方英尺
Project Area: 2,800 sq ft
住宅原型建在华盛顿,花岗岩瀑布,位于西雅图东北部大约50英里的小瀑布山脉。第二个原型是圣地亚哥城市正规划中的建筑。这住宅是一系列项目的一部分,探索新的技术和使用预制建筑方法和材料,以建立低成本,高品质的住宅,构建位置适应和程序适应的人造建筑。
This prototype is built near Granite Falls, Washington, in the Cascade Mountains about 50 miles north east of Seattle. A second prototype is in the planning stages for an urban site in San Diego. This house is part of a series of projects that explore the opportunities for using prefabrication techniques and new building construction methods and materials to build low cost, high quality, site-adaptable and program-adaptable manufactured buildings.
>> 浏览全部 21 张图片
美国俄勒冈州波特兰现代派住宅
2010-4-22
设 计 师:Webster Wilson
所 在 地:美国 俄勒冈州 波特兰
设计师Webster Wilson在波特兰内城的死火山的山坡上建造了这座住宅,这是一座人文主义风格的现代派住宅设计。这座现代住宅的设计中使用了大量天然木材和石材,而且这些材料的表面并没有进行涂漆处理。大面积的空地和充足的自然光照是这座住宅的特色。住宅位于山坡高处,因此在住宅任何一楼的任何一间房间里都能欣赏到周围的景色。住宅的外壁上可以看到带暗斑多节的杉木和风化的树皮。住宅总面积为2600平方英尺,内有4间卧室、3.5间浴室、1间工作室、1间厨房、1间洗衣室、1间主人套房(位于屋顶平台上)等等。节能灯、绝热铝质窗架、太阳能板和其它一些事物充分体现了住宅的环保设计。
>> 浏览全部 14 张图片
魁北克国立美术学院设计(参赛作品)
2010-4-22
所 在 地:加拿大 魁北克
该设计包括一个盛大的绿色屋顶,尽管看起来似乎是一个相当不稳定的斜坡,这里也是人们出入口。两个巨大的透明正立面可展现博物馆内部展馆,同样也引入了足够多的可见光。尽管两个正立面呈相反方向,但屋顶一直延续到地面,与现有公园建筑相互连接。
The design includes a grand green roof that, although it seems to slope at quite a precarious angle, is accessible for people to walk on. The sweeping form surrounds two large facades that reveal the changing exhibitions inside the museum. These massive windows also flood the interior with daylight. As the two facades rise opposite each other, the roof lines connect to the ground and continue the existing park onto the actual building.
>> 浏览全部 13 张图片
SHIP住宅
2010-4-22
所 在 地:日本 兵库 西宫
总面积:193.65平方米
建筑面积:63.27平方米
总楼层面积:111.54平方米
Site Area: 193.65 sqm
Built Area: 63.27 sqm
Total Floor Area: 111.54 sqm
该住宅建在一个高差3米的地块上。由于对周边开发建筑的堤防和挡土墙信誉度的关注,后建筑的地基就建在了天然地面上,作为支撑层更加可靠。钢筋外表面的体块被用作是公共空间,“漂浮”于挡土墙之上,这里可欣赏到美丽的风景。私人空间被安排在底层,这里氛围比较平静,远离道路,采用了结识的混凝土结构,并且平衡了上部的悬臂体块。
A residence built on a two-tiered site with a level difference of 3 meters. Because of the concern remained about the credibility of embankment and retaining wall built along the housing development, the foundation was laid on natural ground beneath the lower tier which was more reliable as the supporting stratum. The steel-made volume for public rooms floats over the retaining wall and above the upper tier for better view. Private rooms are arranged along the lower tier where the atmosphere is calm, at a distance from the front road, within a reinforced concrete structure which functions as a counterbalance to the overhanging volume.
>> 浏览全部 16 张图片
Middelfart储蓄银行
2010-4-22
所 在 地:丹麦 Middelfart
竞赛年限:2005
项目年限:2010
Competition Year: 2005
Project Year: 2010
3XN建筑事务所获得Middelfart储蓄银行新总部设计的竞赛提案奖。该建筑必须要为雇员构建出完美的环境,同时也积极的应对了海滨未来发展对建筑质量的要求。
该建筑拥有一个巨大的屋顶覆盖整个建筑。屋顶采用木质网格结构,优雅大方。开放的网格屋顶可以丰富的引入日光,从建筑各个角度直接看到周边海景。这样,该总部大厦就缔造出了充足的光线和友好的工作氛围。
3XNs visionary and empathetic winning proposal unites the Middelfart savings Bank’s high ambitions for their new head office. The building must ensure a perfect environment for the employees, while also positively stress demands for high architectural quality in the future development along the harbour front.
One large roof covers all functions in the building. The roof is a large elegant wooden structure with numerous openings. The openings bring in abundant amounts of daylight and allow for direct view of the sea from all places in the building, up and down. In this way, the light and friendly atmosphere sought for by the bank is achieved.
>> 浏览全部 11 张图片
K大厦
2010-4-22
所 在 地:荷兰 阿姆斯特丹
NL建筑事务所设计的K大厦是荷兰阿姆斯特丹500住房整体规划的一部分。三角形的地段座落在历史中心区和近期开发的海港区之间。大厦体块的尺寸是31*28平方米,大约有2.5层高。据总体规划确定的指导方针,它强制性的构建前两层,第三层包括50%的屋顶平台。
NL Architects‘ Blok K is part of a master plan for 500 dwellings in Amsterdam. The site’s triangular shape sits between the historic center and the recently redeveloped harbor area. The block measures 31 x 28 meters and is about 2.5 stories tall. According to the guidelines established in the master plan, it was obligatory to build the first two stories in alignment and the third story had to contain 50% roof terrace.
公共建筑设计
51.18 万条内容 · 448 人订阅
洗浴中心的平面图
各位同仁。谁有洗浴中心的平面图,借看一下,两层就行,谢谢。
