土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 外文翻译
外文翻译
发布于:2010-04-08 13:28:08 来自:建筑设计/建筑资料库 [复制转发]
在做毕业设计,现需要一篇外文,有的请发邮箱 676621006@qq.com,谢谢!
  • yuhang0124
    yuhang0124 沙发
    摘 要
    xxxx学楼建筑结构设计,位于xx省xx市。
    本工程占地面积约800平方米,建筑面积4383.7平方米。本建筑主体六层,总高度27米,室内外高差为0.60米,女儿墙高0.9米。建筑采用矩形,总长度为64.94 米,总宽度为12.3 米。建筑立面规整,女儿墙实心砖砌筑,正门为铝合金门,窗为塑钢窗。本工程结构形式为钢筋混凝土现浇结构,柱子混凝土强度等级为C30,截面500500,框架梁混凝土等级C30,截面为300700。建筑地点地质条件良好,采用柱下独立基础,混凝土强度C30。
    设计严格遵守我国现行规范 ,计算中包括荷载计算,内力组合,基础设计,楼梯设计等。在设计过程中,应用大学所学知识,使我们加深理解并将只是融会贯通已达到最好的利用,提高自己的能力。
    关键词:
    教学楼; 梁; 板; 柱; 荷载; 内力; 基础; 楼梯。
    Abstrsct
    xxxx, whice is located in xx city xxx province.
    This projection covers the area of 800square meters which own four storeys. the total building areas are 4383.7 square meters. Total height is 27m,between indoors outside the height difference is for 0.60m,The daughter wall are0.9m.The shape of the building plan is L. The total length is 55.2 m,total width is 18.6m the design in formal . Using white ceramic bricks to decorate the outside wall, using solid bricks to build the daughter wall. Choosing Alloy door as the front door.The windows use plastic-- steel windows.
    The structural form of the civil engineering is the form of reinforcement concret casting .The strength class of the frame column is C30.The cross sections of the first floor is 500500. The strength class of the frame is C30,and the cross sections are 300700 .The soil condition of the building site is so good, so using the under column independent foundation with the concret of C30.Using a avoiding shaking seams which met the needs.
    The design strictly complied with the currently used code of our country . The calculation includes the calculation of the load, the composition of internal force , the design of the foundation and the calculation of the stairs . In the design we use the knowledge which we learned in the college,this make the knowledge what we learned full use and we could improve ours ability.
    KEY WORDS:
    Teaching building; Beam; Board; post; Load; Internal force; Basis; Stairs.
    2010-04-08 16:58:08
建筑资料库
13.61 万条内容 · 216 人订阅
基坑围护设计
贡献力量
