土木在线论坛 \ 建筑结构 \ ANSYS \ 非线性分析不收敛!
非线性分析不收敛!
发布于:2010-04-02 19:46:02 来自:建筑结构/ANSYS [复制转发]
我模拟了单层单品框架的低周反复荷载试验,很难收敛,之前也听说过,混凝土很难收敛,但是我感觉我的模型有问题,附上error文件夹里的内容,希望各位提点建议!谢谢
*** WARNING *** CP = 155.453 TIME= 19:21:27
Specified forces from the previous F command were applied only to
defined and selected nodes.
*** WARNING *** CP = 155.531 TIME= 19:21:27
*** WARNING *** CP = 155.594 TIME= 19:21:27
Node 1012 on element 1 is unselected.
Node 1138 on element 1 is unselected.
Node 1124 on element 1 is unselected.
Node 1095 on element 1 is unselected.
Node 1042 on element 1 is unselected.
*** WARNING *** SUPPRESSED MESSAGE CP = 155.594 TIME= 19:21:28
Node 2285 on element 1 is unselected.
Node 2345 on element 1 is unselected.
Node 2355 on element 1 is unselected.
Node 1042 on element 2 is unselected.
Node 2285 on element 2 is unselected.
Node 2345 on element 2 is unselected.
Node 2355 on element 2 is unselected.
Node 1041 on element 2 is unselected.
Node 2286 on element 2 is unselected.
Node 2340 on element 2 is unselected.
Node 2356 on element 2 is unselected.
Node 1041 on element 3 is unselected.
Node 2286 on element 3 is unselected.
Node 2340 on element 3 is unselected.
ANSYS
4.39 万条内容 · 152 人订阅
ansys命令流
用log文件下载命令流的时候,怎么清理掉以前的命令流??我的log里面存在着自从安装开始就有的命令流,复制的时候很不方便,哪位大哥帮解答一下,小弟先谢谢啦
