土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ Granite slabs
Granite slabs
发布于:2010-03-17 19:06:17 来自:建筑设计/居住建筑设计 [复制转发]
Granite slabs is a slice of granite cut from a granite block that is used to make beautiful granite countertops. Slabs can also be used to create other objects like benches, steps, pavers, mantles and more. Most of our slabs are sold to commercial and industrial companies that transform them into decorative products,such as kitchen tops, bar tops, vanity tops, steps, window sills…etc.
Our main granite countertop slabs are chinese stone material,G682,G603,G654,G681,G687 is popular and cheatest china granite. A portion are imported from prestigious quarries in Europe and India. By cutting the slabs ourselves, we can control the quality of the final product.
Kao shi stone is the granite slab specialists! Our strict quality guidelines assure you the best products available. From size to colour, we make sure every single detail is up to our highest standard. We also can provide big orders easily, which is greatly appreciated by our industrial and commercial clients.
居住建筑设计
28.74 万条内容 · 423 人订阅
农村自用房设计方案
自家亲戚农村住房用 让我帮他做个方案 小弟刚学因为楼板都买过了是3700的 所以三个开间都是3米7的大致是这样的设计的 面积是9X11。1M各位大哥给我看看我的这个怎么样?都有那些错误?还有什么好的改动没?
