土木在线论坛 \ 建筑结构 \ ANSYS \ Ansys V12 软件介绍(E文)
Ansys V12 软件介绍(E文)
发布于:2010-02-28 06:20:28 来自:建筑结构/ANSYS [复制转发]
Ansys Products v12.1 x86/x64 Final ISO-MAGNiTUDE | 7.69GB
ANSYS 12 delivers innovative, dramatic simulation technology advances in every major physics discipline, along with improvements in computing speed and enhancements to enabling technologies such as geometry handling, meshing and post-processing. These advancements alone represent a major step forward on the path forward in Simulation Driven Product Development. But ANSYS has reached even further by delivering all this technology in an innovative simulation framework, its latest-generation ANSYS Workbench.
Install the packages. Install the license manager. Make sure you put the Magnitude folder contents in a place where the license file can be generated. Once generated, use the license manger to install the license file you created. Supports 2 users. Useful for testing because their tech support is horrible.
More-complex analyses involving multiple physics can be built up by connecting systems. Data dependencies are indicated clearly as connections. State icons at the right of each cell indicate whether cells are up to date, require user input or need to be updated - for example, whether they are just meshed or fully solved.
In addition to serving as a framework for the integration of existing applications, the ANSYS Workbench platform also serves as an application development framework and ultimately provides project-wide scripting, reporting, a user interface (UI) toolkit and standard data interfaces.
Further advancing the adaptive architecture of ANSYS Workbench and its ability to fit into your design and engineering processes, release 12.0 introduces the ability to record, customize and automate analysis steps with journaling and scripting. Journaling captures operations that modify data in an ANSYS Workbench session and records them in a journal file. Such a file can be replayed to return the state of an ANSYS Workbench session exactly. Alternatively, a journal can be modified to change or incorporate additional operations, which are referred to as scripting. Many applications hosted in ANSYS Workbench support their own scripting languages (e.g. Mechanical APDL) and these application-specific commands can be can be embedded in a ANSYS Workbench script. This coordination between ANSYS Workbench and its individual applications provides comprehensive scripting support of the complete engineering simulation process.
Install Note:
1) unRAR and burn
2) check ".txt" from "\MAGNiTUDE" dir
3) enjoy another fine MAGNiTUDE-release!
  • fjt_121
    fjt_121 沙发
    太好了,谢谢了。楼主辛苦了
    2010-03-02 17:00:02
ANSYS
4.39 万条内容 · 152 人订阅
ansys结构分析指南(下)
