土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ Windows 7 支持的 Autodesk Products
发布于:2010-01-27 00:38:27 来自:建筑设计/CAD下载及教程 [复制转发]
AutoCAD 2010
AutoCAD Architecture 2010
AutoCAD Electrical 2010
AutoCAD Inventor LT Suite 2010
AIP 2010 with Autodesk Inventor Tooling 2010 Add-In
AutoCAD Inventor Professional Suite 2010
AutoCAD Inventor Routed Systems Suite 2010
AutoCAD Inventor Simulation Suite 2010
AutoCAD Inventor Suite 2010
AutoCAD Inventor Tooling Suite 2010
AutoCAD LT 2010
AutoCAD Mechanical 2010
AutoCAD MEP 2010
Autodesk Algor Simulation 2010
Windows 7 support for Revit 2010 products and previous versions
Autodes Revit Architecture 2010
Autodesk Revit MEP-B 2010
Autodesk Revit MEP 2010
Autodesk Revit Structure 2010
说明:
Windows 7 is not a tested environment for Revit 2010 and previous version products. You may be able to use Windows 7 and a Revit 2010 or previous version product, however, we may not be able to resolve every issue you encounter at this time.
  • fdgfd35fgfdgd354
    支持2009吗?
    2010-03-11 10:50:11
  • yao_qi_zhi4
    yao_qi_zhi4 板凳
    谢谢版主分享,看看是否有用?
    2010-02-07 11:05:07
CAD下载及教程
52.09 万条内容 · 690 人订阅
国家一级设计师十年用CAD精髓
刚刚从朋友那里搞来的“精髓”,与大家共享
