土木在线论坛 \ 建筑结构 \ 结构资料库 \ Application of nonlinear optimizati
发布于:2010-01-20 15:57:20 来自:建筑结构/结构资料库 [复制转发]
论文简介:
This study presents a nonlinear optimization technique (NOT) for conducting the back analyses of geotechnical engineering problems
based on the field observations. Additional auxiliary techniques are incorporated to enhance the convergence and stability of the NOT.
The developed NOT and additional auxiliary techniques are incorporated into a finite element code and then applied to the back analysis
of excavation-induced wall deflection. A number of hypothetical excavation cases with various scenarios of stratigraphy and two quality
excavation case histories are used to validate the developed NOT, in which the dominant soil parameters are treated as target parameters.
Results show that the wall deflections of all hypothetical and actual excavation cases at each stage can be accurately and efficiently backfigured.
附件名:20101201263974244450.zip
文件大小:506K
(升级VIP 如何赚取土木币)
结构资料库
41.29 万条内容 · 428 人订阅
2009年11月的《建筑抗震设计规范》送审稿
才出的吧,大家看看!
