土木在线论坛 \ 建筑结构 \ 结构资料库 \ An Experimental Study of MR Dampers for Seismic Protection
发布于:2010-01-07 23:13:07 来自:建筑结构/结构资料库 [复制转发]
S.J. Dyke,1 B.F. Spencer Jr.,2 M.K. Sain3 and J.D. Carlson4
Abstract
In this paper, the efficacy of magnetorheological (MR) dampers for seismic response reduction
is examined. To investigate the performance of the MR damper, a series of experiments was
conducted in which the MR damper is used in conjunction with a recently developed clipped-optimal
control strategy to control a three story test structure subjected to a one-dimensional ground
excitation. The ability of the MR damper to reduce both peak responses, in a series of earthquake
tests, and rms responses, in a series of broadband excitation tests is shown. Additionally, because
semi-active control systems are nonlinear, a variety of disturbance amplitudes are considered to
investigate the performance of this control sytstems over a variety of loading conditions. For each
case, the results for three clipped-optimal control designs are presented and compared to the performance
of two passive systems. The results indicate that the MR damper is quite effective for
structural response reduction over a wide class of seismic excitations.
结构资料库
41.29 万条内容 · 430 人订阅
Covariance Control Using Closed Loop Modeling for Structures
Covariance Control Using Closed Loop Modeling for Structures1Jianbo Lu and Robert E. Skelton2AbstractThis paper presents a low order controller design method, using closed loop modelingplus covariance control, with application to the benchmark problem in structural control
