土木在线论坛 \ 电气工程 \ 电气资料库 \ 南方电网公司110kV及以下配电网设备装备技术导则Q/CSG 10703-2009
发布于:2009-12-20 11:09:20 来自:电气工程/电气资料库 [复制转发]
中国南方电网公司企业标准Q/CSG 10703-2009
2009-3-16发布
目 次
前 言............................................................................III
1 范围...............................................................................1
2 规范性引用文件.....................................................................1
3 名词术语...........................................................................3
4 总则...............................................................................5
5 通用技术原则.......................................................................6
5.1 电压等级.........................................................................6
5.2 短路电流.........................................................................6
5.3 电能质量.........................................................................6
5.4 电气主接线.......................................................................7
5.5 中性点接地方式...................................................................7
5.6 变电站站用电.....................................................................8
5.7 过电压保护与绝缘配合.............................................................8
5.8 防雷与接地.......................................................................8
5.9 无功补偿及电压调整...............................................................9
5.10 继电保护与自动化...............................................................10
5.11 通信...........................................................................11
5.12 防灾减灾.......................................................................11
6 变(配)电站及开关站型式与布置....................................................12
6.1 110kV变电站.....................................................................12
6.2 35kV变电站......................................................................12
6.3 开关站与配电站..................................................................13
7 主要电气一次设备..................................................................13
7.1 变压器..........................................................................13
7.2 高压组合电器....................................................................15
7.3 断路器..........................................................................16
7.4 隔离开关与接地开关..............................................................17
7.5 电流互感器......................................................................18
7.6 电压互感器......................................................................19
7.7 避雷器..........................................................................19
7.8 中性点接地装置..................................................................20
7.9 母线............................................................................21
7.10 开关柜.........................................................................22
7.11 熔断器.........................................................................23
7.12 10kV柱上开关...................................................................24
7.13 无功补偿装置...................................................................26
7.14 低压电器.......................................................................27
8 直流系统与交流不间断电源..........................................................29
8.1 直流系统........................................................................29
8.2 交流不间断电源(UPS)...........................................................31
8.3 一体化电源设备..................................................................33
8.4 通信电源........................................................................33
9 继电保护与变电站自动化............................................................33
II
9.1 继电保护........................................................................33
9.2 自动装置........................................................................36
9.3 变电站综合自动化................................................................37
10 调配自动化与信息化...............................................................39
10.1 县级调配自动化系统.............................................................39
10.2 配电网自动化系统...............................................................40
10.3 配电网管理信息系统.............................................................43
10.4 电能质量监测...................................................................44
11 计量与营销自动化.................................................................44
11.1 计量...........................................................................44
11.2 营销自动化系统.................................................................45
12 配电网通信.......................................................................46
12.1 通道配置.......................................................................46
12.2 通信组网.......................................................................46
12.3 设备要求.......................................................................47
12.4 应急通信.......................................................................49
13 线路.............................................................................49
13.1 架空线路.......................................................................49
13.2 电缆线路.......................................................................53
14 安防系统.........................................................................55
14.1 火灾自动报警系统...............................................................55
14.2 图像监视及安全警卫.............................................................55
14.3 其它...........................................................................56
15 节能环保.........................................................................56
附录A................................................................................58
附录B................................................................................59
附录C................................................................................61
附录D................................................................................63
附录E................................................................................64
附录F................................................................................66
附录G................................................................................67
附录H................................................................................68
前 言
为把中国南方电网有限责任公司建设成为经营型、服务型、一体化、现代化的企业,建设结构合理、
可靠经济、技术先进、信息畅通的现代化配电网,提高南方电网110千伏及以下配电网装备科技含量和
自动化水平,指导配电网技术发展,规范设备配置与选型的基本原则和标准,特制定本导则。
本导则以国家及行业的有关法律法规、标准、导则为基础,结合目前装备的技术水平、运行经验和
管理要求而提出,本导则以国家及行业的有关法律法规、标准、导则为基础,结合目前装备的技术水平、
运行经验和管理要求而提出,适用于中国南方电网有限责任公司及所属(含代管)各有关单位2009~
2013年110千伏及以下配电网新建与改造、设备采购和运行管理工作。
本导则由中国南方电网有限责任公司标准化委员会批准。
本导则由中国南方电网有限责任公司生产技术部归口并解释。
本导则起草单位:深圳供电规划设计院有限公司、佛山南海电力设计院工程有限公司
广东省电力设计研究院、贵州电力设计研究院
昆明供电设计院有限责任公司、广西绿能电力勘察设计有限公司。
本导则参加单位:广西电力勘察设计研究院、海南电力设计院、广州电力设计院
本导则主要起草人:黄志伟、戴新胜、邱野、曲毅、刘映尚、崔鸣昆、余建国、谭伟明、黎智、
蒋浩、王建、张岚、朱敏、黄耀亮、李成、张文军、陈渊书、张杰。
全部回复(47 )
  • 水轮发电机
    资料有普通工作人员指导意义,谢谢楼主
    2022-01-09 11:27:09
  • mine0416
    mine0416 板凳
    谢谢楼主把这么好的资料传上来与我们共享,希望继续加油
    2020-03-23 15:39:23
电气资料库
70.19 万条内容 · 799 人订阅
《建筑电气》06第五期
EIB I_bus总线控制系统用于建筑设备控制 高层建筑导线及电缆分支连接方式的分析比较 高大空间火灾报警系统应用实例 关于设计规范中负荷分级规定编制情况的回顾 国内外ATSE标准主要内容的对比与分析 基于MAS技术的电梯群控系统建模 空港建筑中公共大空间照明的实施对策与分析 利用系数有可能大于灯具效率吗 漏电火灾报警系统实现方法 浅谈谐波的预防和治理 浅谈医院电气可靠性和安全性设计
