土木在线论坛 \ 装修设计 \ 装饰装修材料 \ 寻材料Steel sheet with a PFV coating(急急急)
发布于:2009-10-23 12:24:23 来自:装修设计/装饰装修材料 [复制转发]
最近公司在寻找一种材料,但是我在网上一直没有找到,希望能得到大家的帮助,相关的资料如下:
Base material: Hot-Dip galvanized steel sheet
Quality: DX 51 D
Top side film: Single side laminated, 100% Fluoride film
Minimum layer thickness: 38 pm
Material: PVF, Tedlar ® (Dupont ®)
Color: GH15 (Grey)
Back side film Single side laminated, PE coating, and compatible for PUR injection
Protection film PE film (Optional)
Cold or hot rolled flat soft steel sheet with an even thickness, on the top side foreseen with a PVF coating and on the backside foreseen with a PE coating suitable for PUR injection adhesion and cold deformation of the sheet.
The coating layers applied shall not crack, flake or peel during mechanical processing with observance of the minimum deformation radius.
(Sheet thickness < 1,25 mm → Minimum radius 1 x sheet thickness)
Applications: Lines and equipment with circular shape Lines and equipment with angular shape Removable and screwed boxes
Heads and bottoms of equipment
Tank walls
Use: In highly corrosive environments or exposure to certain chemicals.
(Chemical resistance shall be checked in advance)
Form and dimensions:
- On coil Width 1.000 mm
- Flat sheet Length x Width 1.000 mm x 2.000 mm
- Flat perforated sheet Length x Width 1.000 mm x 2.000 mm
- Corrugated sheet - Waved Dimension in function of the application
- Corrugated sheet - Trapezium Dimension in function of the application
  • qgpei1225
    qgpei1225 沙发
    钢板喷涂PFA
    少见
    但是国内应该有
    2009-10-23 12:52:23
  • lanqinglong
    lanqinglong 板凳
    自己顶一个先,有消息请联系我 QQ18875590, email: lanqinglong@163.com 谢谢
    2009-10-23 12:27:23
装饰装修材料
6.35 万条内容 · 209 人订阅
建材图片
建材图片 建材图片 建材图片
