土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ green roof
green roof
发布于:2009-10-19 06:17:19 来自:站务休闲/闲聊茶吧 [复制转发]
system installation
.root barrier is loose laid
.drainage layer is rolled out(geotextile layer facing up)
.water retention layer is rooled out (either side facing up)
.pre-cultivated mat is laid out
.place gravel on open spaces over drainage layer between edges of roof and bee-hive drains
闲聊茶吧
114.52 万条内容 · 201 人订阅
09年卡巴斯基杀毒软件促销小姐舞照
