土木在线论坛 \ 建筑结构 \ 结构设计软件 \ 【求助】用sap算一水缸上环形铁箍。
【求助】用sap算一水缸上环形铁箍。
发布于:2009-10-05 19:32:05 来自:建筑结构/结构设计软件 [复制转发]
用sap 计算水缸上的一个环形的铁箍,如下图: 下载 (1.23 MB)
2009-9-7 21:09
计算模型如下: 下载 (812.6 KB)
2009-9-7 21:09
有如下结果:
(弯矩) 下载 (812.6 KB)
2009-9-7 21:09
(轴力) 下载 (879.54 KB)
2009-9-7 21:09
现有如下问题:
1.0 分析时有一段话 如下,
B E G I N A N A L Y S I S 2009/09/04 15:47:19
MAXIMUM MEMORY BLOCK SIZE (BYTES) = 31.905 MB
NUMBER OF JOINTS IN THE MODEL = 8
E L E M E N T F O R M A T I O N 15:47:19
NUMBER OF FRAME ELEMENTS FORMED = 8
L I N E A R E Q U A T I O N S O L U T I O N 15:47:19
FORMING STIFFNESS AT ZERO (UNSTRESSED) INITIAL CONDITIONS
TOTAL NUMBER OF EQUILIBRIUM EQUATIONS = 48
APPROXIMATE "EFFECTIVE" BAND WIDTH = 15
NUMBER OF EQUATION STORAGE BLOCKS = 1
MAXIMUM BLOCK SIZE (8-BYTE TERMS) = 636
SIZE OF STIFFNESS FILE(S) (BYTES) = 5.172 KB
NUMBER OF EQUATIONS TO SOLVE = 48
* * * W A R N I N G * * *
NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION SOLUTION:
TYPE LABEL DOF X-COORD Y-COORD Z-COORD PROBLEM VALUE
Joint 5 UX .000000 78.740157 .000000 Lost accuracy 15.5 digits
Joint 5 UY .000000 78.740157 .000000 Diag = 0 --> 1.00E-10
Joint 5 UZ .000000 78.740157 .000000 Lost accuracy 15.5 digits
Joint 5 UZ .000000 78.740157 .000000 Diagonal < 0 -3.55E-15
Joint 5 RX .000000 78.740157 .000000 Lost accuracy 15.0 digits
Joint 5 RX .000000 78.740157 .000000 Diagonal < 0 -4.09E-12
Joint 5 RY .000000 78.740157 .000000 Lost accuracy 14.5 digits
Joint 5 RY .000000 78.740157 .000000 Diagonal < 0 -7.73E-12
Joint 5 RZ .000000 78.740157 .000000 Lost accuracy 12.5 digits
EXCESSIVE LOSS OF ACCURACY WAS DETECTED DURING THE SOLUTION OF EQUATIONS
NUMBER OF DIGITS LOST EXCEEDED 11.0
THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!
CHECK THE STRUCTURE CAREFULLY FOR:
- INADEQUATE SUPPORT CONDITIONS, OR
- ONE OR MORE INTERNAL MECHANISMS, OR
- ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR
- EXTREMELY LARGE STIFFNESS PROPERTIES, OR
- BUCKLING DUE TO P-DELTA OR GEOMETRIC NONLINEARITY, OR
- A FREQUENCY SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
NUMBER OF EIGENVALUES BELOW SHIFT = 3
L I N E A R S T A T I C C A S E S 15:47:19
USING STIFFNESS AT ZERO (UNSTRESSED) INITIAL CONDITIONS
TOTAL NUMBER OF CASES TO SOLVE = 1
NUMBER OF CASES TO SOLVE PER BLOCK = 1
LINEAR STATIC CASES TO BE SOLVED:
CASE: DL
A N A L Y S I S C O M P L E T E 2009/09/04 15:47:19
这么多warning 是什么意思?是没有加支座的关系吗?
2.0 这个模型我是没有加支座的,这样可以吗?如果不可以,又怎么会分析得出结果呢?(分
析出来的结构我觉得合理)如果要加支座要加在哪里?在四个角上?为什么?
[ 本帖最后由 sharewqm 于 2009-10-5 19:34 编辑 ]
  • wuyufeng2009
    wuyufeng2009 沙发
    等我学牛了,我要来论坛解答你们的疑惑,呵呵。。。加油,继续学习~~~~~~~~~~~~~~~~~~~~~~~~~
    2009-12-30 16:48:30
结构设计软件
41.51 万条内容 · 299 人订阅
【求助】请问sap屈曲(buckling)分析时得出的屈曲系数代表什么?
请问sap屈曲分析(Buckling)时得出的屈曲系数(Buckling factor ) 代表什么?1.0 正负号代表什么意思?2.0 buckling factor 的绝对值大于1 就代表 OK吗?(我是这样理解的)3.0 顺便问下sap振型分析得出的自振频率或周期有什么用?是跟什么比较的?有些书写了频率大于1Hz就不用考虑风力的动力影响,是这样的吗?
