土木在线论坛 \ 建筑结构 \ ANSYS \ 标准、完整的框架结构ansys命令流分析过程及原文件
发布于:2009-08-06 17:26:06 来自:建筑结构/ANSYS [复制转发]
!********************提示********************************************
!第一步:建立框架结构模型
!第二步:框架结构施加重力荷载
!第三步:框架结构施加活荷载
!第四步:框架结构施加风荷载
!第五步:框架结构荷载组合运算
!第六步:框架结构模态分析
!第七步:框架结构屈曲特征值分析
!第八步:框架结构地震时程弹性分析
!第九步:结束
!采用地震波时间文件为:TIME.TXT
!采用地震波文件分别为:AC_X.TXT/AC_Y.TXT
FINISH
/CLEAR
/FILENAME,FRAME_SHEAR_WALL
/TITLE, FRAME_SHEAR_WALL
!************************第一步********************************************
!********************框架结构建模型***************************************
/PREP7
!采用单位为N/m/S 国际单位制
!定义单元类型
ET,1,BEAM4
ET,2,SHELL63
!定义实常数
R,1,0.25,0.0052,0.0052,0.5,0.5
R,2,0.2025,0.0034,0.0034,0.45,0.45
R,3,0.06,0.0002,0.00045,0.3,0.2
R,4,0.25,0.25,0.25,0.25
R,5,0.1,0.1,0.1,0.1
!定义材料参数
MP,EX,1,3.0E10
MP,NUXY,1,0.2
MP,DENS,1,2500
!关键点
*DO,II,1,1
K, 1+(II-1)*20, 0, 0, (II-1)*6
K, 2+(II-1)*20, 6, 0, (II-1)*6
K, 3+(II-1)*20, 12, 0, (II-1)*6
K, 4+(II-1)*20, 17, 0, (II-1)*6
K, 5+(II-1)*20, 0, 5, (II-1)*6
K, 6+(II-1)*20, 6, 5, (II-1)*6
K, 7+(II-1)*20, 12, 5, (II-1)*6
K, 8+(II-1)*20, 17, 5, (II-1)*6
K, 9+(II-1)*20, 0, 10, (II-1)*6
K, 10+(II-1)*20, 6, 10, (II-1)*6
K, 11+(II-1)*20, 12, 10, (II-1)*6
K, 12+(II-1)*20, 17, 10, (II-1)*6
K, 14+(II-1)*20, 6, 1.875, (II-1)*6
K, 16+(II-1)*20, 6, 3.125, (II-1)*6
K, 18+(II-1)*20, 6, 1.875, 3.9
K, 20+(II-1)*20, 6, 3.125, 3.9
*ENDDO
*DO,II,1,10
K, 1+II*20, 0, 0, (II-1)*3+6
K, 2+II*20, 6, 0, (II-1)*3+6
K, 3+II*20, 12, 0, (II-1)*3+6
K, 4+II*20, 17, 0, (II-1)*3+6
K, 5+II*20, 0, 5, (II-1)*3+6
K, 6+II*20, 6, 5, (II-1)*3+6
K, 7+II*20, 12, 5, (II-1)*3+6
K, 8+II*20, 17, 5, (II-1)*3+6
K, 9+II*20, 0, 10, (II-1)*3+6
K, 10+II*20, 6, 10, (II-1)*3+6
K, 11+II*20, 12, 10, (II-1)*3+6
K, 12+II*20, 17, 10, (II-1)*3+6
K, 13+II*20, 0, 1.875, (II-1)*3+6
K, 14+II*20, 6, 1.875, (II-1)*3+6
K, 15+II*20, 0, 3.125, (II-1)*3+6
K, 16+II*20, 6, 3.125, (II-1)*3+6
K, 17+II*20, 0, 1.875, (II-1)*3+6+1.5
K, 18+II*20, 6, 1.875, (II-1)*3+6+2
K, 19+II*20, 0, 3.125, (II-1)*3+6+1.5
K, 20+II*20, 6, 3.125, (II-1)*3+6+2
*ENDDO
*DO,II,11,11
K, 17+II*20, 0, 1.875, (II-1)*3+6+1.8
K, 18+II*20, 6, 1.875, (II-1)*3+6+2.5
K, 19+II*20, 0, 3.125, (II-1)*3+6+1.8
K, 20+II*20, 6, 3.125, (II-1)*3+6+2.5
*ENDDO
*DO,II,12,12
K, 1+II*20, 0, 0, 39.5
K, 2+II*20, 6, 0, 39.5
K, 3+II*20, 12, 0, 39.5
K, 4+II*20, 17, 0, 39.5
K, 5+II*20, 0, 5, 39.5
K, 6+II*20, 6, 5, 39.5
K, 7+II*20, 12, 5, 39.5
K, 8+II*20, 17, 5, 39.5
K, 9+II*20, 0, 10, 39.5
K, 10+II*20, 6, 10, 39.5
K, 11+II*20, 12, 10, 39.5
K, 12+II*20, 17, 10, 39.5
*ENDDO
*DO,II,2,13
L, (II-1)*20+1, (II-1)*20+2
L, (II-1)*20+2, (II-1)*20+3
L, (II-1)*20+3, (II-1)*20+4
L, (II-1)*20+5, (II-1)*20+6
L, (II-1)*20+6, (II-1)*20+7
L, (II-1)*20+7, (II-1)*20+8
L, (II-1)*20+9, (II-1)*20+10
L, (II-1)*20+10, (II-1)*20+11
L, (II-1)*20+11, (II-1)*20+12
L, (II-1)*20+5, (II-1)*20+9
L, (II-1)*20+6, (II-1)*20+10
L, (II-1)*20+3, (II-1)*20+7
L, (II-1)*20+7, (II-1)*20+11
L, (II-1)*20+4, (II-1)*20+8
L, (II-1)*20+8, (II-1)*20+12
*ENDDO
*DO,II,1,12
L, (II-1)*20+1, II*20+1
L, (II-1)*20+2, II*20+2
L, (II-1)*20+3, II*20+3
L, (II-1)*20+4, II*20+4
L, (II-1)*20+5, II*20+5
L, (II-1)*20+6, II*20+6
L, (II-1)*20+7, II*20+7
L, (II-1)*20+8, II*20+8
L, (II-1)*20+9, II*20+9
L, (II-1)*20+10, II*20+10
L, (II-1)*20+11, II*20+11
L, (II-1)*20+12, II*20+12
*ENDDO
*DO,II,1,1
L, (II-1)*20+14, (II-1)*20+18
L, (II-1)*20+16, (II-1)*20+20
*ENDDO
*DO,II,2,12
L, (II-1)*20+13, (II-1)*20+17
L, (II-1)*20+15, (II-1)*20+19
*ENDDO
A, 1, 21, 25, 5
*DO,II,2,12
A, (II-1)*20+1, II*20+1, II*20+5, (II-1)*20+5, (II-1)*20+15, (II-1)*20+19, (II-1)*20+17, (II-1)*20+13
*ENDDO
*DO,II,1,12
A, (II-1)*20+2, II*20+2, II*20+6, (II-1)*20+6, (II-1)*20+16, (II-1)*20+20, (II-1)*20+18, (II-1)*20+14
*ENDDO
*DO,II,1,12
A, II*20+1, II*20+2, II*20+6, II*20+5
A, II*20+2, II*20+3, II*20+7, II*20+6
A, II*20+3, II*20+4, II*20+8, II*20+7
A, II*20+5, II*20+6, II*20+10,II*20+9
A, II*20+6, II*20+7, II*20+11,II*20+10
A, II*20+7, II*20+8, II*20+12,II*20+11
*ENDDO
!立柱网格划分
LSEL,S,,,181,192 !底层立柱
LATT,1,1,1
LESIZE,ALL,,,10
LMESH,ALL
LSEL,S,,,192,324 !2~12层立柱
LATT,1,2,1
LESIZE,ALL,,,5
LMESH,ALL
!梁网格划分
LSEL,S,,,1,180
LATT,1,3,1,
LESIZE,ALL,,,8
LMESH,ALL
!剪力墙网格划分
LSEL,S,,,372 !外剪力墙两端、内剪力墙顶端
LSEL,A,,,413
LSEL,A,,,461
LESIZE,ALL,,,8
LSEL,s,,,418 !内剪力墙底端
LSEL,A,,,420
LESIZE,ALL,,,3
LSEL,s,,,325 !内剪力墙底端内侧
LSEL,A,,,326
LESIZE,ALL,,,6
LSEL,S,,,375 !剪力墙空洞顶部
LSEL,A,,,379
LSEL,A,,,383
LSEL,A,,,387
LSEL,A,,,391
LSEL,A,,,395
LSEL,A,,,399
LSEL,A,,,403
LSEL,A,,,407
LSEL,A,,,411
LSEL,A,,,415
LSEL,A,,,419
LSEL,A,,,423
LSEL,A,,,427
LSEL,A,,,431
LSEL,A,,,435
LSEL,A,,,439
LSEL,A,,,443
LSEL,A,,,447
LSEL,A,,,451
LSEL,A,,,455
LSEL,A,,,459
LSEL,A,,,463
LESIZE,ALL,,,2
!剪力墙网格划分
ASEL,S,,,1,24
AATT,1,4,2
AMESH,ALL
!楼板网格划分
ASEL,S,,,25,96
AATT,1,5,2
AMESH,ALL
NSEL,S,LOC,Z,0 !选取模型底端节点
D,ALL,ALL !施加位移约束
ALLSEL,ALL !重新选取所有节点
/eshape,1.0
/VIEW,1,1,1,1
/ANG,1,270,XM,0
/REPlot
FINISH
!************************第二步********************************************
!********************框架结构施加重力荷载*********************************
!框架结构施加重力荷载
FINISH
/SOLU
ANTYPE,STATIC
D,ALL,ALL !施加位移约束
ACEL,0,0,9.8
SOLVE
FINISH
/POST1
SET,FIRST
PLNSOL,U,Z,0,1
FINISH
!************************第三步********************************************
!*************框架结构施加楼面活荷载D=3KN/M^2*****************************
!框架结构施加楼面活荷载D=3KN/M^2
FINISH
/SOLU
ANTYPE,STATIC
D,ALL,ALL !施加位移约束
ACEL,0,0,9.8
SOLVE
FINISH
/POST1
SET,FIRST
PLNSOL,U,Z,0,1
FINISH
全部回复(37 )
  • aaa_001_007
    aaa_001_007 沙发
    谢谢楼主的无私奉献!
    2015-04-26 12:52:26
  • wz2shl
    wz2shl 板凳
    谢谢分型哦
    2015-01-06 12:59:06
ANSYS
4.39 万条内容 · 152 人订阅
请教:beam4单元实常数设定
如果是圆环截面,那么thy,thz设置为什么啊?多谢了
