土木在线论坛 \ 人才招聘 \ 学生专栏 \ 推荐:建筑结构中英文翻译(相当于词典)
推荐:建筑结构中英文翻译(相当于词典)
发布于:2005-05-22 16:45:22 来自:人才招聘/学生专栏 [复制转发]
非原创,供大家参考,希望大家遇到此类的问题可以到这儿查查资料。希望对大家有帮助!
A
acceptable quality:合格质量
acceptance lot:验收批量
aciera:钢材
admixture:外加剂
against slip coefficient between friction surface of high-strength bolted connection:高强度螺栓摩擦面抗滑移系数
aggregate:骨料
air content:含气量
air-dried timber:气干材
allowable ratio of height to sectional thickness of masonry wall or column:砌体墙、柱容许高厚比
allowable slenderness ratio of steel member:钢构件容许长细比
allowable slenderness ratio of timber compression member:受压木构件容许长细比
allowable stress range of fatigue:疲劳容许应力幅
allowable ultimate tensile strain of reinforcement:钢筋拉应变限值
allowable value of crack width:裂缝宽度容许值
allowable value of deflection of structural member:构件挠度容许值
allowable value of deflection of timber bending member:受弯木构件挠度容许值
allowable value of deformation of steel member:钢构件变形容许值
allowable value of deformation of structural member:构件变形容许值
allowable value of drift angle of earthquake resistant structure:抗震结构层间位移角限值
amplified coefficient of eccentricity:偏心距增大系数
anchorage:锚具
anchorage length of steel bar:钢筋锚固长度
approval analysis during construction stage:施工阶段验算
arch:拱
arch with tie rod:拉捍拱
arch—shaped roof truss:拱形屋架
area of shear plane:剪面面积
area of transformed section:换算截面面积
aseismic design:建筑抗震设计
assembled monolithic concrete structure:装配整体式混凝土结构
automatic welding:自动焊接
auxiliary steel bar:架立钢筋
全部回复(15 )
  • shihuikkkaaa
    shihuikkkaaa 沙发
    2009-05-21 17:21:21
  • superstar2202
    superstar2202 板凳
    请广大网友们不要跟贴,以保持整洁,以利于朋友们查找资料方便,谢谢大家支持,谢谢。
    2005-05-22 17:05:22
学生专栏
23.9 万条内容 · 138 人订阅
如果有这个机会让你选择。。。
毕业了,你们选择什么?请大家踊跃参与!
