土木在线论坛 \ 装修设计 \ 公装设计 \ 日本在德国开设的面馆,很特别哦,
日本在德国开设的面馆,很特别哦,
发布于:2009-06-24 12:59:24 来自:装修设计/公装设计 [复制转发]
日本在德国开设的面馆,很特别哦,
AnAn is a new Japanese Noogle Bar in Wolfsburg, Germany, designed by Hosoya Schaefer Architects, that represents on a piece of contemporary Tokyo.
The geometric structure developed for the project consists of a series of distorted hexagonal cells organized by a geometric pattern on the floor and the ceiling. The cells are made from thick acryl panels covered with graphic patterns produced by a selection of young graphic designers from Japan. They contain a counter (Yatai), or a table (Kotatsu), vending machines, a coat room or plastic food plates as a three-dimensional menu column.
The constituting grid in the floor is expressed as aluminum lines in the white polyurethane floor, in the ceiling as light strips that illuminate the restaurant. The space is conceived to be both transparent and filled with a range of different graphics and sensibilities creating a heterogeneous, urban whole.
全部回复(35 )
  • c2951234
    c2951234 沙发
    日本Noogle”是一种新的酒吧塔中,德国建筑师设计的一个促进Hosoya,它代表在一块当代东京。
    建立了几何结构工程是由一系列的扭曲的六角形细胞组织的几何模式对地板和天花板。这些细胞是由厚板平面模式内覆盖着由选择年轻的平面设计师来自日本。它们含有一种计数器(亚太),或一个表(Kotatsu)、自动售货机、一件外套房间或食品塑胶板三维菜单栏。
    在地板上的制定网格线表示为铝在白色聚氨酯地板,天花板上的光条,照亮餐厅。空间构思是透明的,充满了各种不同的图形和感性创造一个异类,城市的整体。
    2012-03-29 16:48:29
  • xinzhqiu
    xinzhqiu 板凳
    好漂亮的店啊,设计的真棒,在这样的店了不吃饭都会觉得很美。
    2011-05-05 14:48:05
公装设计
8.03 万条内容 · 210 人订阅
国外精品资料2
Villa Berkel Paul de Ruiter
