土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ AutoCAD表格中的函数
AutoCAD表格中的函数
发布于:2009-06-24 09:40:24 来自:建筑设计/CAD下载及教程 [复制转发]
各位我有一事请教:
在AutoCAD2006中的表格功能是否只含有标准数学函数,没有其他函数(如统计、文本、查找、引用等)?在不同表格间,能否数值引用?
请各位帮帮忙!
小弟谢过了!
  • wtkc
    wtkc 沙发
    When defining the arithmetic expressions - see Fields > All > Expression - you can use the following functions:
    +, -, *, /, ^, () = basic arithmetic operations
    sin(angle) = Sinus of an angle
    cos(angle) = Cosinus of an angle
    tang(angle) = Tangens of an angle
    asin(real) = Arcus sinus
    acos(real) = Arcus cosinus
    atan(real) = Arcus tangens
    ln(real) = Natural logarithm
    log(real) = Decimal logarithm
    exp(real) = Natural power
    exp10(real) = Decimal power
    sqr(real) = Square
    sqrt(real) = Square root
    abs(real) = Absolute value
    round(real) = Rounded to the nearest integer
    trunc(real) = Truncated to integer
    r2d(angle) = Angle in radians converted to degrees
    d2r(angle) = Angle in degrees converted to radians
    pi = Pi constant (Ludolf's number)
    2011-12-27 20:06:27
CAD下载及教程
52.09 万条内容 · 690 人订阅
怎样在CAD视口中显示局部图
怎样在CAD视口中显示局部图
