土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 国外基于位移的抗震设计
国外基于位移的抗震设计
发布于:2009-06-05 09:28:05 来自:建筑设计/建筑资料库 [复制转发]
论文简介:
The conceptual basis of the spectral acceleration-based design method currently used in seismic codes is reviewed and its limi-
tions are discussed. An alternative method that uses displacements as the basis for the design procedure is then presented. Its
nceptual basis for elastic and inelastic seismic design and its application to single-degree-of-freedom and multi-degree-of-freedom
ructures are reviewed. The effects of torsion are considered. The advantages of this method over the spectral acceleration-based
sign method are also discussed. To the authors’ knowledge, this and the accompanying paper mark the first application of the
splacement-based procedure to the seismic design of (steel) buildings.  1999 Elsevier Science Ltd. All rights reserved.
附件名:2009651244165303833.zip
文件大小:163K
(升级VIP 如何赚取土木币)
建筑资料库
13.61 万条内容 · 216 人订阅
国外基于位移的抗震设计
论文简介: The conceptual basis of the spectral acceleration-based design method currently used in seismic codes is reviewed and its limi-tions are discussed. An alternative method that uses displacements as the basis for the design procedure is then presented. Its
