土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 如何学好钢结构稳定理论与应用课程?
如何学好钢结构稳定理论与应用课程?
发布于:2009-05-23 20:54:23 来自:建筑结构/钢结构工程 [复制转发]
一、课程内容简介
在各类钢结构设计中,保持稳定性是经常遇到的问题。从结构整体到构件再
到局部板件,设计时无不涉及到稳定问题,这是钢结构设计的一个显著特点。其原因在于钢材的强度高,构件比较细长,组成构件的板件也比较纤薄,因而在压力作用下很容易失稳。对待钢结构中失稳的可能性,通常采用加以防止的对策,使结构、构件或板件不会因失稳而丧失承载能力;少数情况下则可以考虑板件的屈曲后强度,以获取较好的经济效果。因此,如何防止失稳和利用屈曲后强度,将是本课程的主要内容。
本课程将重点讲述轴心压杆的稳定性、受弯构件的稳定性、压弯构件的稳定性、板件稳定、框架稳定、拱和壳的稳定性及网壳结构的稳定性。在讲述各类构件及板件失稳原理的同时,分析各种构造措施和结构布置方案的合理性。重点讲解扭转失稳、弯扭失稳的基本原理;针对网壳结构的特殊性,重点讲解极值点失稳及分支点失稳的判别准则、平衡路径的跟踪策略及路径转换等理论性较强的内容。
通过本课程的学习,可以使学生全面了解钢结构设计中可能遇到的稳定问题,理解各种情况下失稳的原理,掌握各类稳定设计的要领,以便在设计施工中有效地避免失稳事故的发生。
In each kind of steel structure design, we usually meets the problem that how to keep the stability. No matter the whole structure or the frame members, even the local components, design of them all involve the stability problem, which is a distinguishing feature of steel structure design. The reason lies in that the strength of steel is quite high, while the frame members are long and slender, and the components are very thin, so they intend to be buckling under the compression forces. To solve this problem, generally, it needs to prevent the structure, frame members and components from losing load-carrying capacity because of destabilization. On the other hand, the buckling strength also can be taken into consideration in certain cases for better economic efficiency. Consequently, how to prevent destabilization and make use of the buckling strength is the primary coverage of this course.
This course will mainly talk about the stability of axis compression members, bending members, bending-compression members, components, frames, arches and shells, and the grid structure. Relating the destabilization principles of each kind of members and components, it also includes the analysis on the rationality of every kind of the constitution measures and the array of structure. The course emphasizes on the explanation about the basic principle of the twisting destabilization and the crankle destabilization. To deal with the particularity of the grid structure, the content of much theorization is emphasized, too, such as the criterion of destabilization on the extreme point and the branch point, tracking strategy of the counterpoise path, and the path transition, etc.
Studying of this course can make students roundly understand the problems on stability that they may meet in the steel structrue design, comprehend the destabilization principle under various conditions, and master every kind of main theme of stability design, so that they can avoid the destabilization accidents effectively in designs and constructions.
二、先修课程
工程结构数值分析方法、应用数学基础
三、教材
1、《钢结构稳定理论与应用》(自编讲义),韩庆华,2005
2、《钢结构稳定设计指南》(第二版),陈绍蕃,中国建筑工业出版社,2004
3、《网壳结构稳定性》,沈世钊、陈昕,科学出版社,1999
四、主要参考书目及文献
1、《钢结构稳定理论与设计》,陈骥,科学出版社,2001
2、《弹性稳定理论》,铁摩辛柯著,科学出版社,1965
3、《金属结构屈曲强度》,Bleich F 著,同济大学译,科学出版社,1965
4、《钢结构构件稳定理论》,吕烈武、沈世钊、沈祖炎、胡学仁著,中国建筑工业出版社,1983
5、《工程结构非线性问题的数值方法》,何君毅、林祥都,国防工业出版社,1994
6、Non-linear Finite Element Analysis of Solids and Structures, Crisfield M.A., John Wiley & Sons Ltd.,1991
7、A Fast Incremental/Iterative Solution Procedure that Handles “Snap-through”, Crisfield M.A., Computers & Structures, Vol.13, pp.55-62, 1981
8、《网壳结构技术规程》(JGJ61-2003),中华人民共和国行业标准,2003
9、《钢结构设计规范》(GB50017-2003), 中华人民共和国国家标准,2003
  • xygxd002
    xygxd002 沙发
    在这里说这个有用吗?
    2012-10-08 22:05:08
钢结构工程
46.53 万条内容 · 1223 人订阅
汽机房网架施工图
图纸简介: 网架 附件名:20095231243048590188.zip 文件大小:212K (升级VIP 如何赚取土木币)
