土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 请教板式楼梯的配筋问题
请教板式楼梯的配筋问题
发布于:2009-04-19 10:35:19 来自:建筑结构/混凝土结构 [复制转发]
1 梁板式楼梯:TB-1
1.1 基本资料
1.1.1 工程名称:工程一
1.1.2 楼梯类型:板式 A 型 ( ╱ ) 支座条件:两端弹性
1.1.3 踏步段水平净长 Lsn = 2600mm 梯板净跨度 Ln = Lsn = 2600mm
梯板净宽度 B = 1200mm
1.1.4 低端支座宽度 dl = 200mm 高端支座宽度 dh = 200mm
计算跨度 Lo = Min{Ln + (dl + dh) / 2, 1.05Ln} = Min{2800, 2730} = 2730mm
1.1.5 梯板厚度 h1 = 110mm
1.1.6 踏步段总高度 Hs = 1667mm 楼梯踏步级数 n = 11
1.1.7 线性恒荷标准值 Pk = 1kN/m 均布活荷标准值 qk = 3.5kN/m ψc = 0.7
ψq = 0.4
1.1.8 面层厚度 c1 = 25mm 面层容重 γc1 =20kN/m 顶棚厚度 c2 = 20mm
顶棚容重 γc2 =18kN/m
1.1.9 楼梯自重容重 γb = 25kN/m
1.1.10 混凝土强度等级: C25 fc = 11.94N/mm ft = 1.27N/mm
ftk = 1.78N/mm Ec = 27871N/mm
1.1.11 钢筋强度设计值 fy = 300N/mm Es = 200000N/mm
纵筋合力点至近边距离 as = 25mm
1.2 楼梯几何参数
1.2.1 踏步高度 hs = Hs / n = 1667/11 = 151.5mm
踏步宽度 bs = Lsn / (n - 1) = 2600/(11-1) = 260mm
踏步段斜板的倾角 α = ArcTan(hs / bs) = ArcTan(151.5/260) = 30.2°
踏步段斜板的长度 Lx = Lsn / Cosα = 2600/Cos30.2°= 3009mm
1.2.2 踏步段梯板厚的垂直高度 h1' = h1 / Cosα = 110/Cos30.2°= 127mm
踏步段梯板平均厚度 T = (hs + 2 * h1') / 2 = (152+2*127)/2 = 203mm
1.2.3 梯板有效高度 h1o = h1 - as = 110-25 = 85mm
1.3 均布永久荷载标准值
1.3.1 梯板上的线形荷载换算成均布永久荷载 gk1 = Pk / B = 1/1.2 = 0.83kN/m
1.3.2 梯板自重 gk2 = γb * T = 25*0.203 = 5.08kN/m
1.3.3 踏步段梯板面层自重
gk3 = γc1 * c1 * (n - 1) * (hs + bs) / Ln = 20*0.025*(11-1)*(0.152+0.26)/2.6
= 0.79kN/m
1.3.4 梯板顶棚自重 gk4' = γc2 * c2 = 18*0.02 = 0.36kN/m
gk4 = gk4' * Lx / Ln = 0.36*3.009/2.6 = 0.42kN/m
1.3.5 均布荷载标准值汇总 gk = gk1 + gk2 + gk3 + gk4 = 7.12kN/m
1.4 均布荷载设计值
由可变荷载控制的 p(L) = 1.2 * gk + 1.4 * qk = 13.44kN/m
由永久荷载控制的 p(D) = 1.35 * gk + 1.4 * ψc * qk = 13.04kN/m
最不利的荷载设计值 p = Max{p(L), p(D)} = 13.44kN/m
1.5 支座反力
永久荷载作用下均布反力标准值 Rk(D) = 9.25kN/m
可变荷载作用下均布反力标准值 Rk(L) = 4.55kN/m
最不利的均布反力基本组合值 R = 17.48kN/m
1.6 梯板斜截面受剪承载力计算
Vmax ≤ 0.7 * ft * b * ho
Vmax = 0.5 * p * Ln * Cosα = 0.5*13.44*2.6*Cos30.2° = 15.1kN
0.7 * ft * b * ho = 0.7*1.27*1000*0.085
= 75.6kN ≥ Vmax = 15.1kN,满足要求。
1.7 正截面受弯承载力计算
1.7.1 跨中 Mmax = p * Lo ^ 2 / 10 = 13.44*2.73^2/10 = 10.02kN•m
As = 419mm ξ = 0.124 ρ = 0.49%
实配 Φ12@200 (As = 565mm) 最大裂缝宽度 ωmax = 0.132mm
1.7.2 支座 Mmin = - p * Lo ^ 2 / 12 = -13.44*2.73^2/12 = -8.35kN•m
As = 345mm ξ = 0.102 ρ = 0.41%
实配 Φ12@200 (As = 565mm) 最大裂缝宽度 ωmax = 0.084mm
1.8 跨中挠度验算
1.8.1 挠度验算参数
Mk = 7.91kN•m Mq = 6.35kN•m
Mk -------- 按荷载效应的标准组合计算的弯矩值
Mq -------- 按荷载效应的准永久组合计算的弯矩值
1.8.2 在荷载效应的标准组合作用下,受弯构件的短期刚度 Bs
1.8.2.1 裂缝间纵向受拉钢筋应变不均匀系数 ψ
σsk = Mk / (0.87 * ho * As) (混凝土规范式 8.1.3-3)
σsk = 7914095/(0.87*85*565) = 189N/mm
矩形截面, Ate = 0.5 * b * h = 0.5*1000*110 = 55000mm
ρte = As / Ate (混凝土规范式 8.1.2-4)
ρte = 565/55000 = 0.01028
ψ = 1.1 - 0.65 * ftk / (ρte * σsk) (混凝土规范式 8.1.2-2)
ψ = 1.1-0.65*1.78/(0.01028*189) = 0.506
1.8.2.2 钢筋弹性模量与混凝土模量的比值 αE
αE = Es / Ec = 200000/27871 = 7.18
1.8.2.3 受压翼缘面积与腹板有效面积的比值 γf'
矩形截面,γf' = 0
1.8.2.4 纵向受拉钢筋配筋率 ρ = As / (b * ho) = 565/(1000*85) = 0.00665
1.8.2.5 钢筋混凝土受弯构件的 Bs 按混凝土规范式 8.2.3-1 计算:
Bs = Es * As * ho ^ 2 / [1.15ψ + 0.2 + 6 * αE * ρ / (1 + 3.5γf')]
= 200000*565*85^2/[1.15*0.506+0.2+6*7.18*0.00665/(1+3.5*0)]
= 765.17kN•m
1.8.3 考虑荷载长期效应组合对挠度影响增大影响系数 θ
按混凝土规范第 8.2.5 条,当 ρ' = 0 时,θ = 2.0
1.8.4 受弯构件的长期刚度 B,可按混凝土规范式 8.2.2 计算:
B = Mk / [Mq * (θ - 1) + Mk] * Bs = 7.91/[6.35*(2-1)+7.91]*765.17
= 424.57kN•m
1.8.5 跨中挠度 f
挠度验算时考虑踏步刚度,踏步段等效高度 heq = 159mm 挠度折减系数 η = 0.612
f = 0.612 * 2.8 / 384 * Qk * Lo ^ 4 / B = 0.00447*10.62*2.73^4/424.57*1000
= 6.2mm
f / Lo = 6.2/2730 = 1/440
1.9 板式楼梯平面整体表示方法的注写内容
AT1, h = 110 151.5X11 = 1667 板面:Φ12@200, 板底:Φ12@200
按照MORGAIN出来的计算书,就只有两种,那分布筋要怎么选
全部回复(5 )
  • clayton2013
    clayton2013 沙发
    不对啊,梯板的分布钢筋是每步下一步一根的,但我觉得你板太厚了,2米6的跨100足以
    2013-08-23 10:07:23
  • tinaglf
    tinaglf 板凳
    2010-07-18 23:41:18
140.17 万条内容 · 2232 人订阅
柱子计算长度的问题 新人。。。
设计新人 问些小白问题 麻烦各位1、比如混凝土框架结构顶层无楼盖,有框架梁,这层的柱子是否算是悬臂柱?下端按固结?上端按自由还是铰接考虑?计算长度如何取?2、《混凝土规范》中表7.3.11-2中的计算长度 与 《钢结构规范》中表D-1,D-2的计算系数 有什么关系吗?感觉两者矛盾呢 是不是混凝土柱子就不能按D-1,D-2中的刚度分配来计算μ?而只能按7.3.11-2和-3来选取计算长度?3、比如正常混凝土框架结构中的柱子到底是按有侧移还是无侧移计算呢?
