This can be solved by using ODE equation:
density*c*V*dT/dt=Qgain-Qloss
density: density of floor construction, kg/m3
c: specific heat, J/kgC
V: volume of floor construction, m3
T: floor temperature, C
t: time, s
Qgain: heat obtained by the system
Qloss: heat losses from the floor
全部回答(11 )
t: time, s
