土木在线论坛 \ 园林景观 \ 园林景观原创精选 \ 新型铰接式砌块护坡体系的应用及其计算方法
发布于:2008-12-08 17:30:08 来自:园林景观/园林景观原创精选 [复制转发]
砌块护坡体系设计与应用
龚丽飞,杨捷,程卫国
(美国舒布洛克集团南京优凝舒布洛克公司,南京210005)
摘 要:铰接式砌块护坡作为护坡结构的一种型式,最早在荷兰开始使用,它的优越性已在欧美、日本、韩国等国家得到了充分的证实,并得到了广泛的应用,起得了良好的生态护岸效果。目前,在我国国内这一项技术还处于引进、消化和推广阶段。因此,对铰接式护坡结构的设计计算尚无系统详细的规范加以指导,本文借鉴国外相关工程设计理念和经验,并结合国内类似产品与工程技术,对铰接式砌块护坡的设计计算方法进行系统地总结,为设计提供参考。
关 键 词:铰接式护坡砌块;护坡结构;设计方法;
The application and design methods of articulated concrete block
GONG Li-fei, Yang Jie, CHENG Wei-guo
(Nanjing Uni-sureblock Co. Ltd. of American Sureblock Group Company, Nanjing 210005, China)
Abstract: As one of revetment structures, articulated concrete block has been used firstly and popularly in the Netherlands. Its superiorities have been fully confirmed in Europe and U.S., Japan, South Korea and other countries. This structure was received a wide range of applications and played a good ecological effects in revetment engineering. At present, in China, this technology is still in the stage of introduction, assimilation and promotion, therefore, there is no systematical and detailed criterion for the design of the articulated concrete block structure. Related to foreign engineering design methods and experience, combined with similar domestic products and projects technology, the paper makes a summary of the design of articulated concrete block revetment and references to the designers.
Key words: Articulated concrete block; Revetment structure; Methods of design
1 前 言
目前我国各大中小城市、水系流域内河道整治治理、堤岸工程中广泛采用各类形式的护坡或护岸结构。我国在河道、道路边坡等防护型式主要分为挡墙结构和铺面结构,传统的铺面结构主要有抛石、干砌块石、浆砌块石、钢筋混凝土面板等多种型式,其作用主要是抵御风浪冲击,防止坡面水土流失,河道淤积等多个问题[1]。这些护坡形式在实际应用中存在诸多问题。第一,不具有生态性,坡面不易种草、绿化,破坏了河道原有生态环境;第二,耐久性差,对坡面或堤岸局部变形的适应性差,遇到不好的土质、沉陷、膨胀土、堤防塌陷、结冰隆起或水的扬压力时容易发生局部破坏或结构不稳定性;第三,石材资源的有限使得传统型式铺面结构在平原地区的江、海、湖泊等地的成本不断地提高。
铰接式砌块护坡是一种连锁型预制高强混凝土块铺面系统,作为防止土壤冲刷的一种有效的新措施,具有施工速度快、良好整体稳定性和生态景观性等优点,欧美国家从八十年代中期开始广泛采用此类护坡结构,尤其是在海岸、河道等水流作用环境下。我国国内目前采用的类似结构以及相关技术如混凝土块铰链软体排[2][3]。
2 铰接式护坡铺面系统
在欧美等国家把各种型式的混凝土砌块护坡结构称为ACB体系(Articulated Concrete Blocks System)[5][6[][7][8]。不同砌块结构,构成不同的护坡铺面体系,块体之间通过自身的联锁键或设置联系缆绳形成一整体护坡面体系。
2.1 铰接式护坡砌块构造特点
铰接式护坡砌块亦作为一种混凝土护坡砌块产品,块体在设计上,不能单纯依靠护坡材料自身重量的传统设计思路,根据波浪作用下护坡结构稳定理论而设计的护坡砌块[4] ,通过改变砌块的外形、大小、开孔、互锁构造等特征,提高块体的防护能力。图1为某种铰接式护坡砌块型式,如块体周边侧面均由一竖直面和倾斜锥面所组成,同排相邻块体间形成Y型空隙,避免块体之间相互
5 施工步骤
铰接式护坡在不同应用环境和施工条件下,可采用不同的施工方式,一般的施工步骤主要包括:(1)坡面整平;(2)铺设反滤碎石层或反滤织物;(3)铺设铰接式护坡砌块,可采用人工单块铺设或铰接式铺垫吊装铺设;(5)护脚和堤顶锚固处理;(6)特殊条件下,铰接式护坡面锚固处理等
6 结 论
铰接式护坡砌块作为混凝土砌块护坡的一种型式,通过缆绳的作用在单个散体块连系成整体,在不破坏河道或渠道等岸坡、渠底的生态链的前提下,具有较好抗冲、抗浪、柔性、稳定性和适应性强的护坡结构:
1.铰接式护坡砌块在能满足工程要求的前提下能有效地保持原有生态链,具有良好的生态性和景观效果。
2.施工简便快捷,现场可采用多种施工方式。根据工程现场实际的施工条件,可灵活地拼装铰接式护坡铺垫的尺寸
3.铺面具有柔性特定,能适应基础土层的地形以及后期的变形。
铰接式砌块护坡结构作为新型的结构型式在国内的使用还处在推广阶段,因此设计和施工必须根据工程具体条件,参考国内外的相关技术规范要求指导设计。同时为了能更好地指导与反馈设计和施工,还需进一步对改新型铺面体系做系统的室内外试验研究,以此积累更多的实测数据指导设计和施工。
参 考 文 献
1. GB50286—98, 堤防工程设计规范[S].
2. 李志江, 段斐, 李伟林. 混凝土铰链排在长江中下游护滩工程中应用的研究与实践[J]. 水运工程, 2006, 387(4): 80-81.
3. 程永东, 詹小米. 混凝土铰链联锁软体排在闸坝消能中的应用[J]. 中国农村水利水电,2005, 02: 92-93.
4. 吴美安, 朱一平, 朱勇等. 护坡用混凝土砌块产品的开发设计[J]. 建筑砌块与砌块建筑, 2005, 05:27-30.
5. Simons D.B., and Senturk F.Y.. Sediment Transport Technology[M]. Water Resources Publications. 1976.
6. Klein Breteler M, Bezuijen A. Simplified design method for block revetments[A].In:Proceedings ICE Conference on Coastal Structures and Breakwaters[C]. London: Thomas Telford,1991.423—436.
7. Natural Resources Conservation Service. Use of Articulating Concrete Block Revetment Systems for Stream Restoration and Stabilization Projects[S]. United States Department of Agriculture, 2007.
8.AYRE Associates. Design Manual for Aritculated Concrete Block[S]. Harris County Flood Control District, 2001.
9.Clopper, P.E. and Y.H. Chen. Minimizing Embankment Damage During Overtopping Flow[R]. the Federal Highway Administration, WashingtonmD.C.,1988.
10.Clopper, P.E.. Hydraulic Stability of Articulated Concrete Block Revetment Systems During Overtopping Flow[R]. the Federal Highway Administration, Breau of Reclamation, Soil Conservation Service, and Tennessee Valley Authority,1989.
11.潘军宁, 王登婷, 吴美安等. 波浪作用下混凝土砌块护坡稳定性试验研究[J]. 河海大学学报(自然科学版),2005,33(4):476-481.
12. Klein Breteler, M., K. W. Pilarczyk, T. Stoutjesdijk. Design of alternative revetments[C]. Proceedings of
the 26th International Conference on Coastal Engineering, Copenhagen, Denmark. , 1998.
13. K.W. Pilarczyk. Coastal Protection[M]. A.A. Balkema, Rotterdam.,1990.
14.王登婷, 汪文强. 混凝土护面板厚度计算公式的探讨[J]. 水运工程,2003,351(4):16-18.
15. Army Corps of Engineers. EM 1110-2-1614:Design of Coastal Revetments,Seawalls, and Bulkheads. DEPARTMENT OF THE ARMY U.S.,1995.
16.朱宪武. 混凝土联锁块软体排的受力分析与计算[J]. 水运工程, 2000, 323(12): 21-26.
17. SL/T225-98, 水利水电工程土工合成材料应用技术规范[S].
18.余广明. 堤防防浪护坡设计[M]. 北京:水利电力出版社, 1987.
  • haifeng4016
    haifeng4016 沙发
    xueixlea ,谢谢啊
    2011-01-03 20:51:03
园林景观原创精选
2.38 万条内容 · 111 人订阅
铰接式护坡系统在中国发展研究思路
铰接式护坡系统在中国发展研究思路 南京优凝舒布洛克公司 程卫国 沈阳农业大学 宓永宁一、研究的目的与意义目前在堤防工程的护坡工程常采用抛石、干砌块石、浆砌块石、混凝土和钢筋混凝土板护坡等型式,其作用主要是抵御风浪冲击,防止坡面被雨水冲刷,防止堤防粘性土发生冻胀和干裂,防止非粘土被风吹散以及防止动物的破坏。实践表明,这些护坡形式在实际应用中存在以下问题:(1)抛石护坡有其明显的不足:首先,由于块石是一种散粒结构,没有整体性,在河床随水流的调整过程中,块石随河床的变形发生滚动移位,部分块石会散失,影响护岸工程的稳定和整体护岸的效果,所以抛石护岸需经常维护加固;其次,对某些堤外无滩、深泓逼岸、迎流顶冲的岸段,防洪堤(墙)紧邻河岸,岸线的任何崩退都有可能带来灾难性的后果,要求护岸工程做到一次稳定,此时抛石往往达不到预期的效果;再其次,人为因素太多,质量很难控制,偷工减料已成为抛石过程中极为常见的现象。(2)预制混凝土板护坡由混凝土板块拼装而成,由于块体之间独立工作,整体性较差;现场就近浇制,施工质量难以保证,一般现浇板尺寸较大,常因堤防的不均匀沉陷而产生裂缝。(3)浆砌块石护坡,由于不适应地基沉降和无法检查其堤坝所存在的安全隐患。加之上述三种形式护坡的厚度都较大。总之,它们都存在下面一些致命的缺陷:总体成本高;不易种草、绿化,生态效果差;耐久性差,对河道小规模变形的适应性差,遇到不好的土质、沉陷、膨胀土、堤防塌陷、结冰隆起或水的扬压力时容易发生局部破坏或结构不稳定性;刚性衬砌面一旦发生局部破坏,容易发生大面积的破坏,易导致下面的土壤侵蚀,因为宽大的破碎板块在水流作用下很容易移走。
