土木在线论坛 \ 给排水工程 \ 给排水资料库 \ 有关工业水处理的英文,不太明白,请前辈们帮忙解释一下,谢谢!
发布于:2008-12-06 23:10:06 来自:给排水工程/给排水资料库 [复制转发]
这段有关工业水处理的英文,我不是太明白,请前辈们帮忙解释一下,谢谢
The industrial waste survey involves a procedure designed to develop a flow-and-material balance (物料平衡)of all processes using water and producing wastes and to establish the variation in waste characteristics from specific process operations as well as from the plant as a whole.The results of the survey should establish possibilities for water conservation and reuse and finally the variation in flow and strength to undergo wastewater treatment.
The sewer map should indicate possible sampling stations and a rough order of magnitude of the anticipated flow.
给排水资料库
22.46 万条内容 · 568 人订阅
求助:给排水初学者应该学那些东西
要学给排水可是不知道该从何下手,求助各位大侠!!!!!
