土木在线论坛 \ 建筑结构 \ 结构设计软件 \ 可原来用2002做的图用2007修改后,在2002下打开后复制粘贴不了
发布于:2008-11-18 20:50:18 来自:建筑结构/结构设计软件 [复制转发]
我的机子上装了2002和2007,可原来用2002做的图用2007修改后,在2002下打开后复制粘贴不了(文字可以复制粘贴,但图面上的东西都复制粘贴不了,粘贴显示是空白的),这是什么原因?是不是不兼容的问题?2007我设置是...
这个问题不是CAD2002与CAD2007兼容的问题。
针对这个问题,目前官方已经有了修复程序(Cut and Paste Hotfix)。以下是引用官方网站上的内容,虽然是英文,但是理解起来很容易。大家可以自己按照提示步骤进行操作:
  Cut and Paste Hotfix(关于热补丁)
  This hotfix will correct a problem where cut and paste, copy and paste, block and insert, wblock and insert, and drag and drop operations fail in drawings that are saved in AutoCAD® 2000 and AutoCAD Release 14 file formats.
  Description of Problem(问题说明)
If you open or create a file in AutoCAD 2007 and save it in AutoCAD 2000 or AutoCAD Release 14 file formats and then open the drawing in AutoCAD 2000, 2000i, 2002 or AutoCAD Release 14 and attempt to cut and paste, copy and paste, block and insert, wblock and insert, or drag and drop objects, then these operations will fail.
  Installation Instructions(安装说明)
To install the Cut and Paste Hotfix
步骤1 Close the affected application(s).
步骤2 Find the acdb17.dll file in your product install folder; for example, c:\program files\AutoCAD 2007.
步骤3 Check the version of acdb17.dll.
(1) Right-click acdb17.dll ; click Properties > Version tab. Note the file version.
(2)If the version is greater than or equal to 17.0.103.50, you already have this hotfix. Do not attempt to apply the version of the .dll associated with this hotfix or you could potentially overwrite other hotfixes.
(3)If the version of the .dll is less than 17.0.103.50 then proceed with the installation of this hotfix.
步骤4 Rename the following file:
  Right-click acdb17.dll and rename it as acdb17.bak.
步骤5 Download the acdb17.dll to your product install folder.
Note: If you need to remove this hotfix, simply delete the new acdb17.dll file that you downloaded to the product install folder and restore the file you renamed in step 4 to its original name.
全部回复(3 )
  • woaipanqun
    woaipanqun 沙发
    这是金山翻译的,嘿嘿!
    2008-11-18 23:00:18
  • woaipanqun
    woaipanqun 板凳
    剪切并粘贴修补程序(关于热补丁)
      此修补程序将正确的一个问题,即剪切和粘贴,复制和粘贴,块和插入, wblock和插入,并拖放操作失败的图纸保存在AutoCAD ® 2000和AutoCAD发行14文件格式。
      说明问题(问题说明)
    如果您打开或创建一个文件在AutoCAD 2007 ,并储存在AutoCAD 2000或AutoCAD的释放14的文件格式,然后打开绘图在AutoCAD 2000 , 2000i , 2002或AutoCAD的14版,并试图剪切和粘贴,复制和粘贴,块并插入, wblock和插入,或拖放物体,然后这些行动将会失败。
      安装说明(安装说明)
    要安装剪切并粘贴修补程序
    步骤一关闭受影响的应用程序(星期日) 。
    步骤二查找acdb17.dll文件中您的产品安装文件夹;例如, C : \程序文件\ AutoCAD的2007年。
    步骤三选中的版本acdb17.dll 。
    ( 1 )右击acdb17.dll ;单击属性“版本选项卡。请注意文件版本。
    ( 2 )如果版本是大于或等于17.0.103.50 ,您已经有此修补程序。不要尝试适用的版本。伦理学与此相关的修补程序,或者您可能会覆盖其他的Hotfix 。
    ( 3 )如果版本的。 dll小于17.0.103.50然后着手安装此修补程序。
    步骤四重命名下列文件:
      右击acdb17.dll并重新命名它作为acdb17.bak 。
    步骤五下载acdb17.dll您的产品安装文件夹中。
    注意:如果您需要删除该程序,只需删除新acdb17.dll文件下载到你的产品安装文件夹,并恢复该文件改名为你在步骤4到原来的名称。
    2008-11-18 22:59:18
结构设计软件
41.51 万条内容 · 299 人订阅
圆形基础受力计算
软件简介: 表中红色区域为人工输入区域 附件名:200811181227010809933.rar 文件大小:29K (升级VIP 如何赚取土木币)
