土木在线论坛 \ 环保工程 \ 规范资料 \ Removal of SO2 and NOx from Simulat
发布于:2008-11-17 10:07:17 来自:环保工程/规范资料 [复制转发]
论文简介:
A dry-regenerative adsorption process for the simultaneous removal of sulfur dioxide and nitrogen oxides from power plant flue gases was investigated. Alkalized alumina was used as the adsorbent in a radial flow fixed bed reactor
at a space velocity of 2000 h-1 and temperatures between 100 and 150 ^C. Breakthrough curves and temperatures were measured at the reactor outlet and at several points within the reactor. The process is appreciably exothermic and strong interaction between NO and SO2 uptake is apparent. Adsorbent saturation capacity and the rate of adsorption for SO2 are affected by NO presence. The adsorbent does not show appreciable loss of activity upon repeated regeneration with H2 at 600 ^C. A diffusion-controlled shrinking core model was used to interpret SO2 breakthrough curves and evaluate pertinent rate parameters.
附件名:200811171226887613166.zip
文件大小:999K
(升级VIP 如何赚取土木币)
  • erus
    erus 沙发
    英语版,喜欢,呵呵!不过英语不过关,看得好吃力!
    2008-11-19 09:39:19
规范资料
10.99 万条内容 · 246 人订阅
新生活农村污水处理工程
论文简介: 新生活农村污水处理工程 附件名:200811151226719478172.zip 文件大小:517K (升级VIP 如何赚取土木币)
