土木在线论坛 \ 建筑结构 \ ANSYS \ 各位老大帮我看下这个模型怎么划分网格啊 不胜感激!
发布于:2008-07-10 18:01:10 来自:建筑结构/ANSYS [复制转发]
/prep7
!单元类型
et,1,solid45
!c40混凝土
mp,ex,1,3.25e10 !c50混凝土
mp,prxy,1,0.167 !泊松比
mp,dens,1,2500 !密度
!对称轴
csys,0
n,1,30,7.156
n,2,30.11,7.156
n,3,30,7.5
n,4,61.8,7.156
n,5,61.825,7.156
n,6,61.8,8.1
n,7,93.6,7.156
n,8,94,7.156
n,9,93.6,8.1
n,11,30,7.156,1.6
n,12,30.11,7.156,1.6
n,13,30,7.5,1.6
n,14,30,7.156,3.2
n,15,30.11,7.156,3.2
n,16,30,7.5,3.2
n,17,30,7.156,4.8
n,18,30.11,7.156,4.8
n,19,30,7.5,4.8
cs,13,0,1,2,3
cs,14,0,4,5,6
cs,15,0,7,8,9
cs,16,0,11,12,13
cs,17,0,14,15,16
cs,18,0,17,18,19
!19关键点生成半跨
csys,0
k,1, -0.2785 , -0.1114 ,0.175
k,2, 15.0000 , 6.0000 ,0.175
k,3, 17.5000 , 6.4580 ,0.175
k,4, 20.0000 , 6.8330 ,0.175
k,5, 22.5000 , 7.1250 ,0.175
k,6, 25.0000 , 7.3330 ,0.175
k,7, 27.5000 , 7.4580 ,0.175
k,8, 30.0000 , 7.5 ,0.175
k,9, 30.0000 , 8.1000 ,0.175
k,10, 15, 8.1 , 0.175
k,11, -1.7500 , 8.1000 ,0.175
k,12, -1.7500 , 7.2500 ,0.175
k,13, 5.9692 , 7.2500 ,0.175
k,14, 6.8888 , 7.2500 ,0.175
k,15, 15.0 , 7.2500 ,0.175
k,16, 15.0000 , 7.0232 ,0.175
k,17, -0.6314 , 0.7706 ,0.175
k,18, -0.9759 , 1.2658 ,0.175
k,19, -0.5841 , 0.8114 ,0.175
l,1,2
*repeat,14,1,1
l,10,15
l,15,2
l,17,16
l,1,17
l,19,14
l,18,13
l,18,19
!生成面大面
a,1,2,16,17
a,2,3,4,5,6,7,8,9,10
a,10,11,12,15
a,13,14,19,18
!拖拉线
k,20,-1.7500 , 8.1000 ,-0.175
l,11,20
!拖拉生成体
vdrag,1,2,3,4,,,25
!横系梁
!局部坐标
kl,18,0.5
kl,32.0.5
k,,-0.45475,0.33,
kwplan,1,42,40,41
!横系梁点拱腿
wprota,0,90
vsbw,1
wpoffs,,-4.1
wprota,0,90,
vsbw,5,
vsbw,6,
wpoffs,,,4.1
vsbw,7,
vsbw,8,
wpoffs,,,4.1
vsbw,6,
vsbw,10,
!横系梁点拱肋
WPCSYS,-1 !将工作平面设为与总体笛卡儿坐标一致
wpoffs,-1.75,7.81
wprota,,90
vsbw,3
vsbw,2
wprota,,,-90
wpoffs,,,-4.017
vsbw,10
vsbw,13
wpoffs,,,-3.7
vsbw,2
vsbw,10
wpoffs,,,-3.7
vsbw,13
vsbw,18
wpoffs,,,-3.7
vsbw,10
vsbw,20
wpoffs,,,-3.7
vsbw,3
vsbw,14
wpoffs,,,-3.7
vsbw,20
vsbw,24
wpoffs,,,-3.7
vsbw,14
vsbw,26
wpoffs,,,-3.7
vsbw,24
vsbw,28
!较长那根
wpoffs,,,12.617
vsbw,23
vsbw,3
!压缩一下编号
nummrg,all
numcmp,all
全部回复(3 )
  • chaofan710
    chaofan710 沙发
    建议混凝土用65号单元模拟!
    2010-08-03 10:45:03
  • hehenihaoya168
    extopt
    2010-07-23 17:54:23
ANSYS
4.39 万条内容 · 152 人订阅
如何提取简支梁正规化后的特征向量(正则模态)?
弱问: 有一个简支梁,已经进行了modal分析。子空间迭代法(subspace)。我只会查看振型的图(plot result).但是我现在要提取振型向量,即特征向量。从list result里面的nodal solution可以查看DOF solutions-y-component displacement等。请问究竟哪个是实际以长度单位表示的结点位移,哪个是正则模态(振型向量)?即振型/sqrt(M),M为主质量矩阵。
