土木在线论坛 \ 电气工程 \ 电气资料库 \ 变流量系统中送风温度的优化设计(英文)
变流量系统中送风温度的优化设计(英文)
发布于:2008-06-19 18:11:19 来自:电气工程/电气资料库 [复制转发]
论文简介:
In a variable air volume (VAV) system with 100% outdoor air, the cooling need in the building is satisfied with a certain air flowat a certain
supply air temperature. To minimize the system energy use, an optimal supply air temperature can be set dependent on the load, specific
fan power (SFP), chiller coefficient of performance, outdoor temperature and the outdoor relative humidity. The theory for an optimal
supply air temperature is presented and the heating, ventilation and air-conditioning (HVAC) energy use is calculated depending on supply
air temperature control strategy, average U-value of the building envelope and two outdoor climates. The analyses show that controlling
the supply air temperature optimally results in a significantly lower HVAC energy use than with a constant supply air temperature. The
optimal average U-value of the building envelope is in practise mostly zero.
© 2003 Elsevier B.V. All rights reserved.
附件名:20086191213870319187.zip
文件大小:305K
(升级VIP 如何赚取土木币)
电气资料库
70.19 万条内容 · 799 人订阅
变流量系统中送风温度的优化设计
论文简介: 在以100%室外空气送风的变空气容积系统(VAV)中,当送风温度一定时,房间所需的制冷量与空气的流动情况有关。为了使系统功耗最小化,系统最优的送风温度需要根据制冷负荷、风机功率(SFP)、制冷系数(COP)以及室外空气相对湿度来确定。在现有的送风温度优化理论下,采暖通风空调系统(HVAC)功耗主要取决于送风温度的控制方式、楼房外表面的平均换热系数以及两种室外气候条件。分析表明:控制送风温度使之最优的系统与在恒温系统相比,HAVC的功耗会得到显著的降低。在实际工作中,楼房外表面的最优换热系数大概为零。
