土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑行业分类英语15(施工用语2)
建筑行业分类英语15(施工用语2)
发布于:2008-06-19 13:06:19 来自:人才招聘/学生专栏 [复制转发]
含水量 water content, moisture content
  混凝土剥落 scaling of concrete
  混凝土外加剂 concrete additive, concrete agent
  混凝土浇筑 pouring of concrete
  级配 gradation, grading
  加固 reinforcement, strengthening
  加腋 haunching
  间距 spacing, pit
  建设 building, construction
  建筑安装工程construction and installation work
  建筑材料 building materials
  建筑结构 building structure
  建筑设计院 architecture design institute
  建筑施工 building construction
  检修人孔 inspection manhole
  浇筑 pouring, placing, depositing
  脚手架 scaffold, scaffolding
  结构标高 structural elevation
  进度估计 progress estimate
  净高 clear height
  净距 clear distance
  净空 clearance
  绝对标高 absolute elevation, absolute level
  竣工 completion
  竣工图 “As Built” drawing
  开工 commencement of work
  扩建 extension, enlargement
  离析 segregation
  临时设施 construction site facilities
  临时道路 temporary road
  麻面 hungry spots
  埋入长度 embedment length
  面层 coat, coating
  抹灰 plastering, rendering
  抹灰面层 finish plaster
  模板 form, shutter board
  模板工程 formwork
  喷涂 spray coating, spraying
  膨胀螺栓 expansion bolt, expansion anchor
  平整 leveling
  平整场地 leveling of ground
  坡道, 斜坡道 ramp, slope ramp, slope way
  起吊 hoisting
  砂浆 mortar
  升板 lift slab
  升板法施工 lift slab construction
  施工 construction
  施工单位 construction organization
  施工缝 construction joint, working joint
  施工图 construction drawing
  时效 aging
  试样 sample, test sample
  收缩 shrinkage, contraction
  水灰比 water-cement ratio
  水泥 cement
  水泥抹面 cement plaster
  水泥砂浆 cement mortar
  水泥砂浆找平 cement mortar screeding
  坍落度 slump
  梯子 ladder, stepladder
  提升模板climbing form,climbing shuttering
  温度缝 temperature joint
  误差 error, inaccuracy
  细骨料 fine aggregate
  细石混凝土 fine concrete
  现场预制 site prefabrication
  现浇混凝土 cast-in-place concrete
  相对标高 relative elevation, relative level
  徐变 creep
  养护 curing
  永久变形 permanent deformation
  预留孔 preformed hole, prepared hole
  预埋件 embedded parts, embedded inserts
  预埋螺栓 embedded bolt, inserted bolt
  找平 leveling, screeding
  找平层 leveling coat, leveling course
  振捣 vibration
  振捣棒 poker vibration, vibrating needle, vibrator
  支模 form erecting, erection of shuttering
  最佳级配 optimum gradation
  坐标 coordinate
  • user1000
    user1000 沙发
    你要把这些都一起打包多好,这样大家就轻松了,一步到位嘛
    2008-07-24 16:07:24
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业分类英语14(施工用语1)
施工常用词汇   拌和料 mixture  标准级配 standard grading  补强 strengthening, stiffening  测量 survey, measurement  拆模 form removal  尺寸 dimension, size  抄平 leveling  处理 treatment  搭接 lap joint, lapping, overlap joint
