土木在线论坛 \ 建筑结构 \ 结构资料库 \ 请问结构研究生主要学哪几本教材
我说的是最基础的 必修的那种
我本科毕业就来设计院做结构设计了
想自学下 充实和提升下
要是哪位哥们有电子版的话 帮帮忙 发上来下 那最好不过了
小弟在此先谢了
全部回答(4 )
  • ruby_zhu
    If your focus is on building design:
    High rise building design
    If your focus is on bridge design:
    for concrete, read
    Prestressed concrete design
    for steel,
    read steel bridge design
    If your focus is on underground structures, you need more knowledge in geotechnical engneering as well.
    If your focus is on industrial design, more steel, stability, and associated structures need to be understood.
    Frankly, there are lots of stuff need to be known for sure.
    2008-07-02 07:54:02 来自 PC 评论 举报
  • ruby_zhu
    Advanced structural mechanics
    Structural dynamics
    Advanced concrete design
    Advanced steel design
    Earthquake engineering
    Foundation analysis and design
    If learn by yourself, these courses should cover up the major requirements of structural engineering routine design.
    2008-06-29 09:25:29 来自 PC 评论 举报
结构资料库
41.29 万条内容 · 427 人订阅
