线路电气
A |
安全系数 |
factor of safety |
B |
棒—棒间隙 |
rod-rod gap |
棒形悬式绝缘子;长棒形绝缘子 |
long rod insulator |
棒形支柱绝缘子;实心支柱绝缘子 |
solid-core post insulator |
保护措施 |
protection measure |
保护角 |
angle of shade |
保护爬电距离 |
protection creepage distance |
避雷器 |
arrester |
扁钢;条钢 |
flat bar |
变电站 |
substation |
变异系数 |
coefficient of variation |
标称电压 |
nominal voltage |
标称荷载 |
normal load; primary load |
标称截面 |
nominal cross-sectional area |
标贯试验 |
standard penetration test |
标准大气条件 |
standard reference atmosphere |
表面泄漏电流计 |
surface leakage tester |
冰荷载 |
ice loading |
并沟线夹 |
parallel groove clamp |
补修管 |
repair sleeve |
补修条 |
patch rods |
不等高档 |
sloping span; inclined span |
不均匀覆冰 |
uneven ice accumulation |
不平衡张力 |
unbalanced tension |
C |
残留机械强度 |
residual mechanical strength |
残余电流 |
residual current |
残余电压 |
residual voltage |
操作过电压 |
switching overvoltage |
槽型连接 |
clevis and tongue coupling |
测量误差 |
error of measurement |
层 |
layer |
差转台 |
booster station |
场强 |
filed strength |
超高压 |
extra high voltage |
充电电流 |
charging current |
冲击过电压耐受电压 |
impulse overvoltage puncture withstand voltage |
初伸长率 |
initial elongation |
穿缆(式)套管 |
draw lead bushing |
船体(悬垂线夹的) |
body ( of a suspension clamp) |
垂直荷载 |
vertical load |
垂直排列 |
vertical configuration |
瓷管 |
porcelain tube |
瓷横担绝缘子 |
porcelain cross-arm insulator |
瓷夹板 |
porcelain cleat |
瓷件 |
ceramic insulator part |
瓷绝缘子 |
ceramic insulator |
磁损 |
magnetic loss |
次档距振动 |
subspan oscillation |
从悬垂挂点起算的第一个间隔棒 |
first spacer away from the suspension point |
D |
搭接 |
lap joint; overlap |
搭接接头 |
lap joint |
大风 |
high wind |
大跨越 |
large crossing |
大爬距绝缘子 |
long leakage distance insulator |
代表档距 |
equivalent span; ruling span |
带电的(用于作业) |
energized ( in live working) |
带电作业 |
live working; live work |
单导线 |
single conductor |
单回路 |
single circuit |
单回线 |
single circuit line |
单极线 |
monopolar line |
单向对地故障 |
single phase- earth fault |
单芯线 |
solid conductor |
档 |
span |
档距 |
span length |
档距中央 |
midspan |
导地线的单丝 |
individual wire |
导线(架空线路的) |
conductor ( of an overhead line) |
导线表面场强 |
conductor surface filed intensity |
导线布置 |
conductor arrangements |
导线对地高度 |
height of conductor above ground |
导线金具 |
conductor fittings |
导线排列 |
conductor configuration |
导线舞动 |
conductor vibration |
导线外层绞向 |
stranding direction of outermost layer |
倒三角排列 |
delta configuration |
等高档 |
level span |
等值附盐量 |
equivalent salt deposit |
等值附盐密度 |
equivalent salt deposit density |
等值盐密度 |
equivalent salt density |
等电位高升 |
ground potential rise |
地面场强 |
ground level filed intensity |
地下电缆 |
underground cable |
地线;架空地线 |
earth wire; shield wire |
地线返回电流 |
returning current from the earth wire |
地线间隙 |
shield wire spacing |
地震荷载 |
earthquake load |
地震烈度 |
earthquake intensity |
电场 |
electric field |
电场强度 |
electric field strength |
电场效应 |
electric field effect |
电磁干扰 |
electromagnetic interference |
电磁感应 |
electromagnetic induction |
电磁环境 |
electromagnetic environment |
电磁兼容 |
electromagnetic compatibility ( EMC) |
电磁骚扰 |
electromagnetic disturbance |
电磁噪声 |
electromagnetic noise |
电导率 |
electrical conductivity |
电动势 |
electromotive force |
电弧试验 |
power arc test |
电击 |
electric shock |
电缆标识 |
cable marking stake |
电缆蛇形敷设 |
snaking of cable |
电离 |
ionization |
电力金具 |
electric power fitting |
电平 |
level |
电气安全距离 |
electric safely distance |
电气化铁路 |
overhead electric traction line |
电气间隙 |
electrical clearance |
电气设备定额电压 |
rated voltage for equipment |
电容(式)套管 |
capacitance graded bushing |
电视干扰 |
television interference |
电晕 |
corona |
电阻 |
resistance |
垫板 |
filler plate |
蝶式绝缘子 |
shackle insulator |
冻雨 |
freezing rain |
镀锌钢绞线 |
stranded galvanized steel wire |
短路电流 |
short-circuit currents |
断线工况 |
broken wire condition |
对地电压 |
voltage with respect to earth |
对地净距 |
clearance to ground |
对角塔腿断面 |
diagonal leg profile |
对障碍物的净距 |
clearance to obstacles |
多回路(线路) |
multiple circuit line |
多雷 |
high lighting incidence |
多元件绝缘子 |
multi- element insulator |
E |
额定动稳定电流 |
rated dynamic current |
额定热短时电流 |
rated thermal short time current |
二分裂导线 |
twin bundle |
F |
法定荷载 |
legislative load |
反击 |
back flashover |
防腐 |
protection against corrosion |
防雷设计 |
lighting protection design |
防污措施 |
measurement against pollution |
防震锤 |
vibration damper |
放松(孤立)档 |
slack span |
飞车 |
spacer car |
非带电的(用于带电作业) |
dead ( in live working) |
非居民区 |
nonresidential area |
非均匀冰荷载 |
non-uniform ice loading |
分裂导线 |
conductor bundle |
风荷载 |
sub-conductor spacing |
风速不均匀系数 |
wind speed nonuniformity coefficient |
风向玫瑰图 |
wind direction rose chart |
风向频率 |
wind direction frequency |
风压 |
wind pressure |
风载档距 |
wind span |
风载体形系数 |
shape factor of wind load; drag factor |
辅助设施 |
ancillary service |
负荷电流 |
load current |
负荷下的偏移 |
deflection under load |
负极 |
negative pole |
附件;紧固器件 |
fitting; fixing device |
复合绝缘子 |
composite insulator |
复合绝缘子的界面 |
interfaces of a composite insulator |
复合绝缘院子的外套和伞 |
housing and sheds of a composite insulator |
覆冰 |
ice accretion |
覆冰厚度 |
ice thickness |
G |
干弧距离 |
dry arcing distance |
干扰 |
interference ( influence) |
干扰源 |
interference source |
干扰允许值 |
limit of interference |
干式交联 |
dry- type cross- linked |
杆塔标志牌 |
tower sign |
杆塔定位 |
locating of tower |
杆塔明细表 |
structure list |
杆塔位平断面图 |
plan and profile drawing |
杆塔中心桩 |
tower center per pile |
感性耦合 |
inductive coupling |
感应电流 |
induced current |
感应电压 |
induced voltage |
刚性绝缘子 |
rigid insulator |
钢化玻璃 |
toughened glass |
钢化玻璃绝缘子 |
toughened glass insulator |
钢芯 |
steel core |
钢芯铝合金绞线 |
steel reinforced aluminum alloy conductor |
钢芯铝绞线 |
steel reinforced aluminum conductor |
高差 |
difference in levels |
高电压 |
high voltage |
高可靠性电力线路 |
high- reliability power line |
工频 |
power- frequency |
工频电压 |
power- frequency voltage |
工频湿耐受电压 |
wet power- frequency withstand voltage |
工作荷载 |
working load |
股线 |
wire; strand |
鼓形绝缘子 |
knob insulator |
故障电流 |
fault current |
挂点 |
attachment point |
挂钩 |
hook |
挂线板 |
attachment steel plate |
光滑导线 |
smooth body conductor |
光纤接续盒 |
optical fiber joint box |
硅橡胶 |
silicone rubber |
过电压保护 |
overvoltage protection |
H |
海底电缆 |
submarine cable |
航空警告标志 |
aircraft warning marker |
合成绝缘子 |
荷载标准值 |
standard value of load |
荷载设计值 |
design value of load |
荷载系数 |
load factor |
荷载状态 |
loading case |
荷载组合 |
loading assumptions |
横断面 |
transverse profile; section profile |
横向荷载 |
transverse load |
洪水位 |
flood stage |
洪水淹没区 |
flooded area |
弧垂 |
sag |
弧垂模板 |
sag template |
弧垂张力曲线 |
sag and tension chart |
户内支柱绝缘子 |
indoor post insulator |
户外(内)—浸入式套管 |
outdoor( indoor)- immersed bushing |
户外(内)套管 |
outdoor( indoor) bushing |
户外直柱绝缘子 |
outdoor post insulator |
护套 |
housing; sheath; sleeve |
护线条 |
armor rods |
滑落 |
slide down |
环境温度 |
ambient temperature |
环境影响 |
environmental impact |
换流站 |
converter station |
换位 |
transposition |
回流线(辅助接地线) |
auxiliary ground wire |
回路 |
circuit |
回转式悬垂线夹 |
pivot- type suspension clamp |
回转轴 |
trunnion |
J |
击穿 |
puncture |
击穿电压 |
puncture voltage |
机电破坏荷载 |
electromechanical failing load |
机械冲击强度 |
impact load |
机械耐受负荷 |
mechanical withstand load |
机械破坏负荷 |
机械强度 |
机械设计 |
mechanical design |
极限设计荷载 |
ultimate design load |
极 |
pole |
极大风速 |
extreme wind speed |
极限档距 |
maximum individual span |
极限设计 |
ultimate strength design |
极性 |
polarity |
集肤效应 |
skin effect |
集中荷载 |
concentrated load |
技术规范 |
technical specification |
技术要求 |
technical requirement |
夹层 |
switch cabin |
加强型绞线 |
reinforced conductor |
加强型铝合金绞线 |
alloy reinforced aluminum conductor (ACAR) |
加权平均值 |
weighted mean value |
架空地线盘形(悬式)绝缘子 |
cap and pin insulator for ground overhead lead |
架空送电线路 |
overhead transmission line |
架空线路 |
overhead line |
间隔棒 |
spacer |
剪应力 |
shearing stress |
降阻剂 |
resistance decreasing agent |
交叉跨越 |
crossing |
交叉角 |
cross angle |
交流线路 |
a. c. line |
交通困难地区 |
difficult transport area |
绞合节距比 |
lay ratio; lay factor |
绞线 |
stranded conductor |
绞向 |
direction of lay |
接触线 |
contact wire |
接地 |
earthing; grounding |
接地电阻 |
grounding (earthing ) resistance |
接地端 |
earth end |
接地故障 |
earth fault |
接地极 |
earth ( ground) electrode |
接地装置 |
counterpoise |
接近 |
parallelism |
接续管 |
mid- span tension joint |
节点板 |
gusset plate |
节距长度 |
length of lay |
节能金具 |
energy- saving fitting |
截面积 |
cross section area |
紧凑型线路 |
compact transmission line |
紧导(地)线 |
stringing of conductor ( earthwire) |
紧固件 |
fastener |
紧固力矩 |
tightening torque |
进线档 |
approach span |
经验公式 |
empirical formula |
警告牌 |
danger plate ( sign) |
静电场强 |
static field strength |
静电放电 |
electrostatic discharge |
静电感应 |
electrostatic induction |
居民区 |
residential area |
局部放电 |
partial discharge |
绝对湿度 |
absolute humidity |
绝缘 |
insulation |
绝缘件 |
insulating part |
绝缘铝导线 |
绝缘水平 |
insulation level |
绝缘套 |
insulating envelope |
绝缘子 |
insulator |
绝缘保护金具 |
insulator protective fitting |
绝缘子串 |
insulator string |
绝缘子串组 |
insulator set |
绝缘子的老化 |
ageing of an insulator |
绝缘子的伞(裙) |
shed of an insulator |
均布冰荷载 |
均压环 |
grading ring |
竣工图 |
as- built drawings |
K |
开挖 |
excavation |
抗扰度 |
interference rejection |
抗弯刚度 |
flexural rigidity |
可见电晕 |
visible corona |
可听噪声 |
audible noise |
空间电荷 |
space charge |
空气间隙 |
air gap |
空气密度 |
air density |
空心支柱绝缘子 |
hollow post insulator |
空芯导线 |
hollow conductor |
控制工况 |
critical case |
跨越公路 |
road crossing |
扩径导线 |
expanded conductor |
L |
拉杆绝缘子 |
link insulator |
拉紧绝缘子 |
strain insulator |
老化 |
aging |
老化试验 |
aging tests |
雷电波 |
lighting surge |
雷电冲击干耐受电压 |
dry lighting impulse withstand voltage |
雷电过电压 |
lighting overvoltage |
雷电流陡度 |
steepness of lighting current |
雷电流幅值 |
amplitude of lighting current |
雷电水平 |
lighting level |
雷电特性 |
lighting performance |
雷击 |
lighting stroke |
连续档;多档 |
multi- span |
联合式基础 |
raft foundation |
邻档 |
adjacent span |
临时拉线 |
temporary guy |
零序阻抗 |
zero sequence impedance |
漏电起痕 |
tracking |
路径 |
line route |
路径图 |
line route map |
路径选择 |
route selection |
铝包带 |
aluminum armor tape |
铝包钢 |
aluminum- clad steel |
铝包钢加强绞线 |
aluminum clad steel reinforced aluminum conductor ( acsr; ac) |
铝合金 |
aluminum alloy |
铝合金绞线 |
all aluminum alloy conductor ( AAAC) |
铝绞线 |
all aluminum conductor ( AAC) |
裸导线 |
bare conductor |
M |
末端效应 |
end effect phenomena |
N |
耐腐蚀 |
corrosion resistant |
耐火性 |
fire resistant |
耐污型绝缘子 |
antipollution- type insulator |
耐压 |
withstand voltage |
耐张串 |
inverted tension set; tension insulator string |
耐张段 |
section |
耐张段长度 |
section length |
耐张绝缘子串 |
tension set |
耐张塔 |
strain ( tension) tower |
耐张线夹 |
anchor cl tension cl dead- end clamp |
耐张转角 |
angle strain |
挠性固定 |
slip fixing |
内部过电压工况 |
internal over voltage condition |
年平均气温 |
mean annual temperature |
扭力 |
torsional force |
扭转刚度 |
torsional stiffness; torsional rigidity |
P |
爬电比距 |
specific creepage distance |
爬电距离 |
creepage distance |
排流线圈 |
drainage coil |
盘形(悬式)绝缘子 |
cap and pin insulator |
配电线路 |
distribution line |
平衡电流 |
balanced current |
平均风速 |
average wind velocity |
平均气温 |
average temperature |
平均应力 |
mean stress |
平均运行张力 |
everyday tension |
平行接近 |
parallelism |
屏蔽环 |
shielding ring |
屏蔽系数 |
screening factor; shielding factor |
破坏荷载 |
failure load |
普通型绝缘子 |
standard- type insulator |
普通支架(臂式支架) |
cantilever bracket |
线路结构
A |
A 型杆塔 |
“A” pole |
安装工况 |
erection condition |
B |
半掏挖基础 |
half-digged foundation |
边相导线 |
side phase conductor |
标准值 |
characteristic value |
标准荷载 |
characteristic load value |
表上层 |
surface horizon |
不等边角钢 |
unequal angle steel |
不等高基础 |
unequal foundation |
不排水剪切强度 |
undrained shear strength |
C |
叉梁、交叉斜材 |
cross bracing |
插入角钢 |
stab angle |
插值法 |
interpolation |
长期荷载工况 |
long term load condition |
长细比 |
slenderness ratio |
承力地层 |
bearing stratum |
承载力 |
load-bearing capacity |
冲孔 |
punching; piercing |
冲刷深度 |
scour depth |
抽样规则 |
sampling rule |
垂直距离 |
vertical distance |
D |
打入桩 |
driven pile |
大腹杆 |
main bracing |
单腹杆 |
single warren; single lacing |
档距系数 |
span coefficient |
挡土墙 |
retaining wall |
导线 |
conductor |
低合金钢 |
low alloy steel |
低碳钢 |
mild steel |
地脚螺栓 |
anchor bolt |
地耐力 |
bearing capacity of the soil |
地下水 |
ground water |
地下水位 |
ground water level |
地线支架 |
earth wire peak |
电缆沟 |
cable through |
电缆构筑物 |
cable building |
垫层 |
pad ( of a foundation) |
冻土 |
frozen ground ( soil, rock) |
镀锌钢 |
galvanized steel |
F |
筏形基础 |
raft foundation |
方横担 |
square crossarm |
方塔身 |
square tower body |
方向桩 |
intermediate line peg |
防波堤 |
break water |
防盗螺栓 |
theft prevention bolt |
防爬装置 |
anti-climbing guard; anti-climbing device |
非均质岩 |
non homogenous rock |
分开式基础 |
separate footing foundation |
分支杆塔 |
branch pole |
分项系数 |
partial factor |
风化岩 |
weathered rock |
风振系数 |
wind fluttering factor |
辅助材 |
redundant bracing ( member) |
辅助横担 |
auxiliary crossarm |
附加荷载 |
additional load |
复合式沉井基础 |
combined sink well foundation |
腹杆系 |
bracing system; lacing system |
G |
杆 |
pole |
杆和支架 |
poles and brackets |
杆塔 |
support; structure ( of an overhead line) |
刚性基础 |
rigid foundation |
钢格栅基础 |
steel grillage type foundation |
钢构件 |
structural steel member |
钢管杆 |
steel pole |
钢筋混凝土板式基础 |
reinforced concrete sheet foundation |
钢筋混凝土杆 |
reinforced concrete pole |
高低腿 |
unequal tower legs |
高低柱基础 |
unequal pole foundation |
高强钢 |
high tensile steel |
格构式塔 |
lattice tower |
格栅式基础 |
grillage foundation |
工作井 |
manhole |
构件 |
component; member |
骨料 |
aggregate |
挂架 |
dropper |
灌注桩 |
cast-in-situ pile; cast-in placed pile; bored-pile |
H |
H 型杆 |
portal support; “H” pole |
夯实 |
compaction |
横担 |
crossarm |
横担拉杆 |
crossarm hanger bar |
横担主材 |
crossarm main member |
横隔 |
plan bracing; diaphragm |
厚度 |
thickness |
护坡 |
slope protection |
换土回填 |
imported backfill |
换位段 |
transposition interval |
换位杆塔 |
transposition support |
换位塔 |
transposition tower |
回填 |
backfill |
回填土 |
backfilled soil |
混凝土保护层 |
concrete cover |
混凝土粗骨料 |
coarse aggregate of concrete |
混凝土浇筑 |
placing of concrete |
混凝土搅拌机 |
concrete mixer |
混凝土台阶式基础 |
benched foundation of concrete |
混凝土细骨料 |
fine aggregate of concrete |
混凝土养护 |
curing of concrete |
混凝土圆柱试样 |
cylinder sample |
活荷载 |
live load |
火曲 |
hot bending |
J |
基础 |
foundation |
基础不均匀沉降 |
uneven settlement of foundation |
基础底板 |
bearing plate |
基础垫层 |
blinding layer |
基础垫层材料 |
underlying foundation material |
基础顶面 |
upper face of the foundation |
基础分坑 |
layout of foundation |
基础钢筋 |
reinforcement steel |
基础混凝土垫层 |
encasing concrete |
基础坑挡土板 |
layer of blinding concrete |
基础立柱 |
sheathing ( of a foundation) |
基础支撑 |
chimney ( of a foundation) |
基石;柱角 |
shoring of foundation |
极限状态 |
limit states |
加长腿 |
hill-side extension; leg extension |
加强筋 |
reinforcing rods |
夹角 |
angle between; included angle |
脚钉 |
step bolt |
铰接 |
pin connection |
节点 |
node; panel point |
局部稳定 |
local stability |
K |
K 形腹杆 |
“K” bracing; K panel |
抗力分项系数 |
resistance partial coefficient |
可变荷载 |
variable load |
刻痕钢丝 |
indented steel wire |
坑 |
excavation; pit; pole |
孔边距 |
edge distance |
扩孔桩 |
expanded pile; bulb pile; under-reamed pile |
L |
拉 V 塔 |
guyed vee tower |
拉杆 |
gang member |
拉猫塔 |
guyed delta tower |
拉伸试验 |
tensile test |
拉线 |
guy; stay; stay wire |
拉线棒 |
anchor rod |
拉线地锚 |
guy anchor |
拉线杆塔 |
stayed support |
拉线盘 |
anchor |
拉线塔 |
guyed tower |
联板 |
yoke plate |
雷暴日数 |
thunderstorm days |
M |
锚固件 |
anchoring parts; anchoring elements |
锚栓 |
anchor bolt |
摩擦角 |
angle of friction |
N |
耐张杆塔 |
tension support; angle support |
挠度 |
deflection |
内摩擦角 |
angle of internal friction |
P |
平口 |
waist |
坡口 |
groove |
Q |
浅槽 |
channel |
(岩石)强风化 |
strongly weathered; highly weathered |
曲臂 |
fork; “K” frame |
全方位高低腿 |
unequal support legs |
R |
热浸镀锌 |
hot dipped galvanizing |
人口密集地区 |
densely populated area |
人口稀少地区 |
sparsely populated area |
软弱下卧层 |
S |
三腹杆 |
triple warren; triple lacing |
散水 |
muff; apron |
上拔工况 |
uplift condition |
上拔荷载 |
uplift load |
上拔基础 |
uplift foundation |
受拉构件 |
tension member |
受力材 |
stress carrying member |
受压构件 |
compression member |
双腹杆 |
double warren; double lacing |
双固定 |
double fixed |
水平距离 |
horizontal distance |
水平偏移 |
horizontal deviation |
水平档距 |
horizontal span |
瞬时破坏张力 |
instantaneous destruction of tension |
隧道 |
tunnel |
T |
塔 |
tower |
塔基断面图 |
cross- section sketch |
塔脚 |
foot; footing |
塔脚板 |
suspension center on tower |
塔上的吊点 |
attachment of sling |
塔身 |
tower body |
塔身风压填充系数 |
solidity ratio of tower body |
塔身加长段 |
body extension |
塔身坡度 |
body slope |
塔头 |
top hamper; super structure |
塔腿 |
tower leg |
塔腿定位 |
positioning of tower legs |
塔腿延伸 |
leg slope |
塔位 |
tower location |
塔型 |
tower type |
碳钢 |
carbon steel |
掏挖 |
undercut; dig; scoop out; hollow out |
套管接头 |
sleeve joint |
体形系数 |
drag coefficient |
铁塔波阻抗 |
tower surge impedance |
铁塔长短腿 |
unequal leg extension |
铁塔单线图 |
tower outline |
铁塔构造 |
tower framing |
铁塔破坏性试验 |
destructive test of tower |
通道 |
channel |
土壤分类 |
soil classification |
土壤剪切强度 |
soil shear strength |
土壤抗压强度 |
soil compressed strength |
土壤容重 |
weight of soil |
土壤液化 |
liquefaction of soil |
土体 |
soil mass |
W |
污秽等级 |
pollution grade |
污秽特征 |
contamination and humid characteristics |
X |
现浇墩型基础 |
pad and chimney foundation; cast-in-situ pier |
线间距离 |
wire spacing |
线路转角 |
line deviation angle |
小腹杆 |
redundant bracings; secondary bracings |
楔 |
cleat |
斜材 |
bracing member |
斜柱基础 |
pad and stub foundation; oblique cylinder foundation; oblique column foundation |
Y |
压注桩 |
pressure injected pile |
岩锚基础 |
rock anchor foundation |
引弧环 |
arcing ring |
引下线 |
downlead line |
永久荷载 |
permanent load |
预制基础 |
prefabricated foundation |
原状抗拔土体 |
undisturbed soil with uplift resistance |
原状土基础 |
undisturbed soil foundation |
Z |
招弧角 |
arcing horn |
真型试验 |
full scale testing |
整体基础 |
block foundation; mass-type foundation |
正应力 |
normal stress |
支架 |
bracket |
直线杆塔 |
intermediate support |
直线耐张 |
tangent strain |
直线塔 |
tangent tower |
直线悬垂 |
tangent suspension |
直线转角塔 |
flying angle support; running angle support |
中横担 |
beam gantry; bridge; girder |
终端杆塔 |
terminal support |
终端塔;锚塔;耐张塔 |
dead-end tower; terminal tower |
重冰地区 |
heavy ice area |
重力式基础 |
gravity type foundation |
主材 |
main leg |
主筋净距 |
main reinforcement clearance |
转动连塔挂板 |
tower swivel clevis |
转角 |
deviation angle |
转角杆塔 |
angle support |
转角终端 |
angle deadend |
转角塔 |
angle tower |
转角杆 |
angle pole |
钻孔 |
drilling |
钻孔灌注桩 |
bored pile |
装配式基础 |
assembly foundation; fabricated foundation |
桩基础 |
pile foundation |
自立杆塔 |
self-supporting support |
自立塔 |
self-supporting tower |
组合构件 |
built-up members |
组塔 |
erection of tower |
组装试验 |
assembly test |
阻尼间隔棒 |
damping spacer |
最大使用张力 |
maximum imposed tension |
最小配筋量 |
minimum amount of reinforcement |
本文转至 西北电力设计院送电室 微信公众号,图文版权归属原作者, 如有侵权请联系删除。
免费1人已点赞
电气资料库
返回版块70.19 万条内容 · 799 人订阅
高压开关柜里藏着的 5 个冷知识,90% 的人都不知道在大多数人的认知里,高压开关柜是 “严肃”“专业” 的电力设备代表,似乎只与复杂的电路、严谨的运维相关。但实际上,在其金属柜体和精密元件的背后,藏着不少容易被忽略的 “冷知识”,这些细节不仅体现了电力技术的巧思,更关乎设备的安全与寿命。 一、SF6 断路器里的 “气体密码”:它比空气重 5 倍,还能 “追踪泄漏” 提到高压开关柜的核心部件 SF6 断路器,很多人知道它用 SF6 气体绝缘灭弧,但很少有人了解这种气体的 “特殊性格”。SF6 气体的密度约为空气的 5.1 倍,这意味着一旦发生泄漏,它不会像氢气那样向上飘,而是会像水一样在柜体底部、电缆沟等低洼处 “聚集”—— 这也是运维时必须重点检查柜体底部密封性的原因。
