本文我们将从结构、运行原理、优劣势和主要应用四个方面,对这三种空调系统进行对比分析,以期为空调系统的选型和设计提供参考。
2.2 优势与劣势
氟冷多联机的优点包括:
1 )系统效率高,能耗低;
2 )室内机种类多,安装灵活;
3 )可实现同时制冷和制热,满足个性化需求;
4 )分户计量容易实现,有利于推广应用。
缺点包括:
1 )冷媒管路长,充注量大,施工要求高;
2 )室外机噪声大,选址受限;
3 )冷媒泄漏风险高,需定期检查和维护 [4] 。
2.3 主要应用场合
氟冷多联机广泛应用于对舒适性和灵活性要求较高的建筑,如办公楼、酒店、公寓等。在改造项目中,氟冷多联机以其安装便捷、低土建要求等优势,也得到了越来越多的青睐。
参考文献:
[1] Aynur, T. N. (2010). Variable refrigerant flow systems: A review. Energy and Buildings, 42(7), 1106-1112.
[2] Goetzler, W. (2007). Variable refrigerant flow systems. ASHRAE Journal, 49(4), 24-31.
[3] Masuda, M., Wakahara, K., & Matsui, K. (1991). Development of a multi-system air conditioner for residential use. ASHRAE Transactions, 97, 127-131.
[4] Park, Y. C., Kim, Y. C., & Min, M. K. (2001). Performance analysis on a multi-type inverter air conditioner. Energy Conversion and Management, 42(13), 1607-1621.
[5] Chua, K. J., Chou, S. K., & Yang, W. M. (2010). Advances in heat pump systems: A review. Applied Energy, 87(12), 3611-3624.
[6] Hepbasli, A., & Kalinci, Y. (2009). A review of heat pump water heating systems. Renewable and Sustainable Energy Reviews, 13(6-7), 1211-1229.
[7] Zhu, Y., Jin, X., Du, Z., Fan, B., & Fu, S. (2014). Generic simulation model of multi-evaporator variable refrigerant flow air conditioning system for control analysis. International Journal of Refrigeration, 36(6), 1602-1615.
[8] Aynur, T. N., Hwang, Y., & Radermacher, R. (2009). Simulation comparison of VAV and VRF air conditioning systems in an existing building for the cooling season. Energy and Buildings, 41(11), 1143-1150.
免费2人已点赞
制冷技术
返回版块14.68 万条内容 · 886 人订阅
空调制冷系统设备安装强制要求、一般要求、精益要求来源 | 机电天下公众号(id:mepbbs)整理总结,如需转载请注明出处 一、制冷机组安装 1.强制要求 1.1 采用隔振措施的制冷设备或制冷附属设备,其隔振器安装位 置应正确;各个隔振器的压缩量,应均匀一致,偏差不应大于2mm。
