转自 “ 网络技术联盟站 ”
| 描述 | 思科 | 华为 |
| 取消、关闭当前设置 | no | undo |
| 显示查看 | show | display |
| 退回上级 | exit | quit |
| 设置主机名 | hostname | sysname |
| 进入全局模式 | en, config terminal | system-view |
| 删除文件 | delete | delete |
| 重启 | reload | reboot |
| 保存当前配置 | write | save |
| 创建用户 | username | local-user |
| 禁止、关闭端口 | shutdown | shutdown |
| 显示当前系统版本 | show version | display version |
| 查看已保存过的配置 | show startup-config | dispaly saved-configuration |
| 查看当前配置 | show running-config | display current-configuration |
| 取消所有debug命令 | no debug all | Ctrl+d |
| 删除配置 | erase startup-config | reset saved-configuration |
| 退到用户视图 | end | return |
| 登出 | exit | logout |
| 指定信息中心配置信息 | logging | info-center |
| 进入线路配置(用户接口模式) | line | user-interface |
| 启动配置 | start-config | saved-configuration |
| 当前配置 | running-config | current-configuration |
| host名字和ip地址对应 | host | ip host |
| 描述 | 思科 | 华为 |
| 配置明文密码 | enable password | set authentication password simple |
| 进入接口 | interface type/number | interface type/number |
| 进入vlan 配置vlan管理地址 | interface vlan 1 | interface vlan 1 |
| 定义多个端口的组 | interface range ethID to ID | port-group 1 group-menber ethID to ID |
| 设置特权口令 | enable secret | super password |
| 配置接口状态 | duplex (half/full/auto) | duplex (half/full/auto) |
| 配置端口速率 | speed (10/100/1000) | speed (10/100/1000) |
| 配置trunk | switchport mode trunk | port link-type trunk |
| 添加、删除vlan | vlan ID / no vlan ID | vlan batch ID / undo vlan batch ID |
| 将端口接入vlan | switchport access vlan | port default vlan ID |
| 查看接口 | show interface | display interface |
| 查看vlan | show vlan ID | display vlan ID |
| 封装协议 | encapsulation | link-protocol |
| 链路聚合 | channel-group 1 mode on | port link-aggregation group 1 |
| 开启三层交换的路由功能 | ip routing | 默认开启 |
| 开启接口三层功能 | no switchport | undo portswitch |
| 对跨以太网交换机的VLAN进行动态注册和删除 | vtp domain | GVRP |
| stp配置根网桥 | spannning-tree vlan ID root primary | stp instance id root primary |
| 配置网桥优先 | spanning-tree vlan ID priority | stp primary vlaue |
| 查看STP配置 | show spanning-tree | display stp brief |
| 描述 | 思科 | 华为 |
| 配置默认路由 | ip route 0.0.0.0 0.0.0.0 | ip route-static 0.0.0.0 0.0.0.0 |
| 配置静态路由 | ip route 目标网段 掩码 下一跳 | ip route-static 目标网段 掩码 下一跳 |
| 查看路由表 | show ip route | display ip routing-table |
| 启用rip、并宣告网段 | router rip / network 网段 | rip / network 网段 |
| 启用ospf | router ospf | ospf |
| 配置ospf区域 | network ip 反码 area | area |
| 配置RIP V2水平分割 | no auto-summary | rip split-hotizon |
| 查看路由协议 | show ip protocal | display ip protocol |
| 标准访问控制列表 | access-list 1-99 permit / deny IP | rule id permit source IP |
| 拓展访问控制列表 | access-list 100-199 permit / deny protocol source IP + 反码 destination IP + 反码 operator operan | rule {normal|special}{permit|deny}{tcp|udp} source {
| 配置HSRP组 | vrrp group-number ip virtual-ip | vrrp vrid number virtual-ip |
| 配置HSRP优先级 | vrrp group-number priority | vrrp vrid number priority |
| 配置HSRP占先权 | vrrp group-number preempt | vrrp vrid number preempt-mode |
| 配置端口跟踪 | vrrp group-number track | 无 |
| 配置静态地址转换 | ip nat inside source static | nat server global
免费1人已点赞
建筑智能化
返回版块12.42 万条内容 · 420 人订阅
智能门禁系统的正确安装和四大故障排除方法引文 门禁系统是现代商业大厦、小区、学校、企业等使用较多的安全保安系统。门禁系统是先洗个现代化安全管理系统,集微机自动识别技术和现代安全管理措施为一体。门禁系统在我们的生活工作中使用较多,但对于门禁系统安装,大家又知道多少呢?下面小编就给大家分享一下门禁系统安装和故障排除的内容。 门禁系统安装 门禁系统安装一:设备安装 1、前端设备
