土木在线论坛 \ 建筑设计 \ 建筑方案设计 \ 都市中的自然栖息地:交子大道木屋顶餐厅
都市中的自然栖息地:交子大道木屋顶餐厅
发布于:2024-06-20 13:50:20 来自:建筑设计/建筑方案设计 [复制转发]
▲漂浮于场地上的轻盈屋面dynamic roof floating on site?xf photography
 基地环境
The Site
成都交子大道是一条两公里长东西向的林荫道,两侧各有约50米宽的人行景观空间,其中散布着二十余个规模几百平米不等的服务驿站,本案即为位于N4-3地块的餐饮建筑。
The avenue of Jiaozi, is a grand boulevard in Chengdu that stretches two kilometers from east to west, with a 50-meter wide of landscape space on both sides. The restaurant is one of the twenty service stations that dots the boulevard.
▲餐厅与交子大道restaurant on Jiaozi Avenue?xf photography
▲东南人视_ southeast view_?xf photography
基地南侧面向城市道路,北面隔着车道为高层住宅塔楼,往东可以远眺交子大道端点的双塔。初次来到场地我们感受到的便是都市的车水马龙与水泥丛林的紧迫感。我们直觉地希望能设计一栋充满自然气息的建筑,一个从建构形式到材料选择上都易于亲近的空间,在紧张忙碌的环境中为人们营造一个放松闲适的用餐场所。
The site is located at the heart of the city, facing the busy street on the south and the soaring high rises on the north, and looking afar the twin towers at the end of the avenue. The sense of place is busy and intense, on first visit we immediately envisioned a proposal that would bring a breath of nature. Working with materials and tectonics that evoke a sense of nature, we try to create a relaxing and approachable setting for people to sit down and enjoy the food.
▲东南侧鸟瞰southeast aerial view?xf photography
▲蜿蜒的屋脊线curved ridge?xf photography
▲扭转的屋面_dynamic twisting roof_?xf photography
 空间概念
The Architectural Concept
餐厅面积约600平米,南侧的两层用餐区最大化地利用景观步道,厨房与后勤空间则靠北集中。场地南面的镜面水池是进入建筑之前重要的过渡空间,水面映射着舒展的屋面与天空,让人们在浮光掠影中放松心情。
The restaurant consists of a double-story dining space on the south and a concentrated back-of-house space on the north. A reflection pool is designed alongside the south fa?ade and becomes a transition from the street to the entry. The water reflects the roof and the sky beyond and calms the mind of diners.
▲西南鸟瞰southwest aerial view?xf photography
▲低垂于镜面水池上的屋面overhanging roof over reflection pool?xf photography
建筑的量体希望建立起坡屋顶的传统四川民居与简洁利落的现代城市之间的对话。餐厅东立面延续了四川传统木结构建筑倾斜的屋顶轮廓与立面肌理,西立面衔接了交子大道周边方整的建筑语汇。两者迥异的形体由一个扭转的屋面自然地连接在一起。屋面的轮廓轻如羽翼,动态起伏的双曲面顺着蜿蜒的屋脊线延展,轻盈地覆盖着下部的餐厅与景观,给予用餐的人们自由奔放、充满动感的空间氛围。
The mass of the project plays with a dialogue between the vernacular architecture and the contemporary cityscape. The east fa?ade celebrates the traditional pitched roof of Sichuan residence while the west fa?ade responds to the context in a rectangle profile. A twisting roof bridges the two sides and acts as a dynamic transition in between. The sprawling surfaces of double-curved roof stretch along a curved ridge in the middle and hover over the dining space and landscape underneath. The profile of the roof is dynamic and light, like the spreading wings of a bird that gently falls on the street.
▲远望双塔view to twin towers?xf photography
▲沿街延展的轻盈屋面dynamic roof stretching along street?xf photography
▲起伏屋面与东侧山墙undulating roof and east gable wall?xf photography
 结构体系
The Structure
建筑的结构为钢木混合结构。斜向交叉的网格状胶合木木梁顺应双曲面形体排布,由室内一路延伸至檐口,形成了人工建构的自然与室外绿意的对话。为了增加稳定性,钢柱在二层楼板以上分叉,并以十字型钢梁搭接到木屋顶两个网格的中心点,形成树枝般的结构构件。
The structure of the project integrates steel columns and timber roof. Laminated timber beams adapt to the double-curved surfaces and extend from inside to outside in a diagonally crossing grids. The continuous pattern of structure unifies the interior and exterior and creates a dialogue between constructed nature and the landscape. To enhance the stability of the structure, each steel column is connected to two center points on grid with cross-shaped transfer beams, resulting in a unique branch-like structural elements on second floor.
▲东侧倾斜的屋顶轮廓pitched roof on east?xf photography
▲沿街立面south fa?ade along the street?xf photography
▲施工照片construction documentation?BEHIVE Architects_致野建筑
本案结构设计的最大挑战在于如何实现屋面在南侧超过4米的悬挑,建筑在前排钢柱的基础上增加了四根斜柱以支撑木梁,使屋面能够低垂于镜面水池之上而无需落柱,同时形塑了沿着幕墙的狭长挑空空间,让在一层的人们也能看见二层生动的木结构。
The biggest challenge of structural design is to achieve the over 4-meter cantilever on south, where the curtain wall recedes. Four inclined columns are added from the foundation of front columns to ensure that the roof floats upon the reflection pool without any support on the outside. The inclined columns also shape a linear void space along the curtain wall, through which visitors from the lower level have a chance to appreciate the dynamic roof.
▲东南广场视角view from plaza?xf photography
▲木梁拼装assembling of timber beams?BEHIVE Architects_致野建筑
04
 外围护表皮系统
The Envelop
建筑立面设计尽可能的通透以突出木结构在室内外的连续感受。南北侧的玻璃幕墙呼应了屋顶木梁的走向,自然而然地形成了连续转折的动态轮廓。在室内灯光的照亮下,街上的行人可以从外侧透过玻璃清晰地看到整个木屋顶。
The fa?ade design aims to achieve maximal transparency to enhance the continuity of timber structure from inside to outside. The curtain wall on south and north follows the crossing grid of the timber beams resulting in a continuous zigzag profile. When the restaurant is illuminated from inside, the timber structure is revealed to pedestrians through the glass.
▲层层叠落的铝板屋面multi-layered aluminum roof?xf photography
▲西南人视southwest view?陈尚儒_photograph by shangru chen
▲屋檐处的悬挑木梁cantilevered beams?BEHIVE Architects_致野建筑
▲扭转的屋面twisting roof?BEHIVE Architects_致野建筑
金属屋面采用了蜂窝幻彩铝板,在阳光下反射环境呈现出渐变的光泽。铝板以层层叠落的形式包裹着动态的屋面,每层表皮之间的断面采用乳白色的亚克力与LED灯,在夜晚它们发出柔和的灯光将屋面层层晕染。
The roof utilizes the aluminum honeycomb panels that reflects the environment and presents gradient color under the sun. The aluminum shell adapts to the form of roof and splits into multiple cascading layers. Translucent acrylic panels and LED lights are used at the splits between the layers and they render the roof with soft glow at night.
▲屋檐处裸露的木结构与曲折的玻璃幕墙exposed timber structure over zigzag glass curtain wall?xf photography
▲扭转的铝板屋面反射环境twisting roof reflects the environment?xf photography
▲屋檐处裸露的木结构exposed timber structure?陈尚儒_photograph by shangru chen
▲从室内延伸至室外的木结构extended timber structure from inside to outside?陈尚儒_photograph by shangru chen
▲低垂于镜面水池上的屋面overhanging roof over reflection pool?陈尚儒_photograph by shangru chen
▲动态的网格状木梁timber beams in a dynamic crossing pattern?xf photography
▲树枝状钢柱与木梁的交接joint between branching columns and timber beams?陈尚儒_photograph by shangru chen
▲动态的网格状木梁timber beams in a dynamic crossing pattern?陈尚儒_photograph by shangru chen
▲木梁下的动线circulation under the roof?陈尚儒_photograph by shangru chen
▲倾斜的木屋顶与下方用餐空间dining space under the pitched roof?xf photography
 技术图纸
DRAWINGS
▲总平面site plan?BEHIVE Architects_致野建筑
▲一层平面1F plan?BEHIVE Architects_致野建筑
▲二层平面2F plan?BEHIVE Architects_致野建筑
▲立面elevation?BEHIVE Architects_致野建筑
▲剖面section?BEHIVE Architects_致野建筑
▲轴测axonometric?BEHIVE Architects_致野建筑
▲量体扭转twisting of mass?BEHIVE Architects_致野建筑
建筑方案设计
21.19 万条内容 · 304 人订阅
OFF SPACE户外生活集合店:户外进阶玩家的露营美学
     yuuuun   露营是场自然界中的社群活动,OFF通过绿地的改造与共享,在有限的条件里尽可能为大家营造一片户外氛围,也是希望传递协作与共建的生活理念。 感谢
