土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 简洁紧凑住宅公寓
简洁紧凑住宅公寓
发布于:2024-06-18 14:06:18 来自:建筑设计/居住建筑设计 [复制转发]
平面图
该合作社是基于90年代圣玛尔塔Hermitage周围的城市化而出现的住宅小区之一,毗邻Monte de Conxo。在目前的城市规划中,住宅使用的建筑是在u型的开放街区中开发的,包括私人使用的内部庭院。
The Cooperative is based on one of the plots of the residential estate that emerged in the 90s from the urbanization of the surroundings of Santa Marta′s Hermitage, next to Monte de Conxo. In the ordination proposed by the current urban planning, the buildings for residential use are developed in open blocks in a U-shape embracing inner courtyards for private use.
平面图
平面图
该建筑显示了对这种配置的兴趣,它被认为是康波斯特拉紧凑街区住宅构成的翻译,利用了在开发单一用途(住宅)时有可能对从街道高度到屋顶的体积给予统一处理的事实。
Showing interest in this configuration, the building is considered as the translation of the compact blocks of Compostela’s residential composition taking advantage of the fact that when developing a single-use (residential) it is possible to give a unitary treatment to the volume from the height of the street to the roof.
剖面图
剖面图
剖面图
因此,设计了一个简洁紧凑的建筑,其立面是通过其整个表面均匀的网格孔组织起来的。从这种恒定的节奏中,住宅单元的内部分布被识别出来,通过在每个孔中插入野生花岗岩的屏幕,使其表面的其余部分完全开放和玻璃,在每个停留中挑出一个可行的元素,即窗户。
As a result, a sober and compact building is proposed, whose facade is organized through a homogeneous grid of holes in its entire surface. From this constant rhythm, the interior distribution of the dwelling units is recognized, by means of screens of wild granite that are inserted in each one of the holes, leaving the rest of its surface totally open and glazed, singling out a practicable element in each stay, the window.
立面图
  立   面图
这样一来,大型的立面画布就形成了,在其中,一般的秩序正在变得细微,空心到空心,空心到空心,被每一个背后的现实所影响。建筑的形状是这样的,直到它到达屋顶,在那里它打破了它的形式规则性,提供了所有高度和视野的可能性。
In this way, the large facade canvases are formed, in which a general order is becoming nuanced, hollow to hollow, void to the void, by the reality behind each one of them. The building is shaped like this until it reaches the roof where it breaks its formal regularity to offer all the possibilities that height and views provide.
在这里,他们将创造一系列与复式住宅相连的花园空间,这些花园空间被赋予了私人景观角,有一个阳光露台和朝向城市南部的特权景观,创造了一组迷宫般的建筑形象,这是住宅区的特点,尽管这里受到允许的最大体积的制约。
Here they will create a series of garden spaces linked to the duplex houses, which are endowed with private landscaped corners with a sun terrace and privileged views towards the south of the city, creating a set of labyrinthine images of the building, characteristic of residential blocks, although here conditioned by the maximum volume allowed.
在底层,有一个公共区域,旨在为建筑的所有用户提供一个真实的客厅。从外面进入是通过一个开放的空间,与社区花园有连续的视觉关系,通往高层的入口。
On the ground floor, there is a common area that is intended as an authentic living room for all users of the building. Access from outside is through an open space in a continuous visual relationship with the community garden to the access portals to the upper floors.
  分析图
一个日光浴室、一个儿童游乐区、一个花园和一个游泳池将使开放的空间充满内容,同时还有遮蔽的空间,在树荫下,辅以一个多功能的封闭空间和一个儿童房。
A solarium, a children's play area, a garden, and a swimming pool will fill the open spaces with content, along with sheltered ones, in the shade, complemented by a multipurpose enclosed space and a children's room.
分析图
项目信息
建筑师:Carbajo Barrios Arquitectos
地点:西班牙
面积:11698 m2
年份:2018
摄影:Luis Díaz Díaz
居住建筑设计
28.74 万条内容 · 423 人订阅
印度古尔冈全新门户地标,现代奢华住宅
由Aedas总监Rafael Acosta 带领团队打造的Signature Global De-Luxe DXP 高层住宅项目,位于印度古尔冈第37D区,由8座塔楼、面积3,200平方米的会所、占地21,000平方米的综合商业区和地下停车场组成,提供了从三居室到横跨三层的复式顶层公寓等多种户型。   Signature Global De-Luxe DXP High Rise Residential is a luxury high-rise residential development in Sector 37D, Gurugram, India comprising 8 towers, a 3,200 sq m Clubhouse as well as an integrated commercial block with 21,000 sq m of retail offerings, and a basement carpark within the development. The development caters to a wide range of residents, offering units from 3 bedrooms to 3-storey penthouses.
