土木在线论坛 \ 建筑设计 \ 建筑方案设计 \ 儿童玩乐? 超能力运动场 —— 更富有趣味性和娱乐性
发布于:2024-06-12 14:18:12 来自:建筑设计/建筑方案设计 [复制转发]
超能力运动场
waa未觉建筑
简介。一个家庭运动中心,通过游戏,重点关注身体运动意识和发展。BE1ST 是 "超能力地图册",是我们从周围世界观察到的特殊品质的集合。我们认为,要收集全年龄段家庭成员发展的超能力,每个 BE1ST 都将代表其中一种超能力。
这个概念的重点是围绕一个虚构的神话岛屿,在这个岛屿的特定位置,这些特殊的超级生物体现了超能力。在该系列的第一版中,我们选择了具有克服极端气候的 "超能力 "的干旱土地观察植物。
仙人掌能在极端干旱的环境中生存,靠的是在茎中储存水分,其强大的根系和针状叶片能提供保护。我们在场馆内模拟了三种具有代表性的仙人掌植物:仙人掌(Carnegiea)、仙人球(Echinocactus)和仙人掌立柱(Opuntia)。
Narrative. A sports centre for the family focuses on Body Movement awareness and development, through play. The BE1ST an “Atlas of Superpower” is a collection of special qualities we can observe in the world around us. waa was commissioned to design a series of family centre’s focusing on sports activity. We believe to collect superpowers of All age family mermbers development, each BE1ST will represent one of these superpowers. The concept focus’s around a fictitious mythical island which situates specific locations these special super organisms embodying superpowers. In this first edition of the series we selected arid land observing plants with ‘superpowers’ to overcome extreme climates. Cacti can survive in extremely arid environments by storing water in their stems, and their robust root systems and needle-like leaves provide protection. We have simulated three representative cactus plants within the venue: saguaro (Carnegiea), Golden Barrel (Echinocactus) and Prickly pears (Opuntia).
总体描述。项目主要的功能由运动设施和家庭共同参与的活动所组成。活动内容包括各类运动课程和虚拟现实的团体游戏,以及高空协调障碍等传统游戏,配以饮品和休息空间,目的是让家庭中各年龄段成员都有运动释放能量的场所。游戏/建筑交叉点的位置。
该项目强调了建筑装置和运动玩乐设备之间的平衡。waa 认为,要使空间更富有趣味性和娱乐性,必须为这两个元素提供融合的机会,而不是单纯的装饰既有设备。在这个场所里,因为尺度受限,我们选择了两个主要的运动场景,一个是以爬和拉伸为主,一个是以钻和探为主。
General description of program. The program consisted of sports and family participating activities for shared learning. Activities include Yoga and exercise classes, VR and AR group games along with high altitude co-ordination obstacles along with more traditional games, supplemented with Food and beverage and resting spaces. Location of play/architecture cross over. The project highlights the balance between architecture and Toy Integration. waa believes that any space to be considered playful, An opportunity is required to be arranged for these two elements to be integrated. Each site will present new opportunities, emphasis was on vertical circulation and the integration in this particular case are two selected games where a hooped frame and barrel tower.
仙人球分析图
a) 仙人球:利用七个球形形体之间的相互关系,我们将室内改造成一个大型的探索工具,让家庭成员锻炼攀爬和爬行的能力。桶形球体内部的结构排列形式是一种投射到球体表面上的网络状结构。在需要的地方,额外的独立柱被用来支撑内部游戏,同时也可以探索桶的周边,所以探索的过程也形成了额外的活动。
a) Barrel Cactus: Using the interconnected relationship between seven spherical forms, we have transformed the interior into a large exploration tool, allowing children to exercise their climbing and crawling abilities. The barrel spheres are a network projected into a sphere. Additional freestanding column supports where needed to support the internal game. This Children can also explore the perimeter of the barrel so process of encasing also formed an additional activity.
仙人掌分析图
b) 仙人掌:我们优化了仙人掌的结构形态,并参考了细胞结构中发现的空间关系。利用直径为4.14米和3.1米的28个圆环,构建两个对称的空间结构,每个环都以径向方式排列。
采用预制的钢管段构建框架,通过焊接固定并覆盖缓冲材料,每个环分为12个段。在这个环形框架上,我们加入了水平攀爬网、滑梯、高空训练元素和装饰性照明。它作为空间内的主要框架,支撑和定位主要的垂直游戏设施。
b) Hoop Cactus: We have optimized the structural morphology of the cactus and referenced the spatial relationships found in cellular structures. Using 28 circular rings with diameters of 4.14 meters and 3.1 meters, we have constructed two symmetrical spatial structures each arranged in a radial manor. Constructed with prefabricated steel tube sections the frame is welded into place and clad with cushioning with each loop split into 12 segments. On this Loop framework, we have incorporated horizontal climbing nets, slides, high-altitude training elements, and decorative lighting. It serves as the primary framework within the space, supporting and positioning the main vertical play facilities
仙人掌立柱分析图
c) 仙人掌立柱:利用仙人掌立柱的垂直形态,将其作为家具元素均匀分布在整个空间中。软垫模块从家具中凸起,并被用作设计工具,以支持直观的游戏功能,包括攀爬点、摇摆的臂膀和台阶,或更高的观察点。作为规划工具,仙人掌立柱可以用来划分不同区域之间的元素,作为视觉导航系统,并通过单一模块化元素实施了功能照明的固定装置。
c) Saguaro: Furniture elements utilizing the vertical form of the Saguaro cactus, have evenly distributed them throughout the space. The cushioned module is elevated from furniture and utilized as a design devise to enable support for intuitive play functions including climbing points, swinging arms and steps or a higher vantage points. As a planning tool the Sagaro can be used to divide elements between different areas, as a Visual way finding systems and can provide fixings for functional lighting have all been implemented through the singular modular element.
d) 沙丘地形:整个场馆地板的地形设计成沙丘的形状。我们使用梯形标准块,尺寸为450x450mm,来抽象沙丘的形态。通过在三个维度上堆叠和排列这些标准模块,地面被转化成一个基本的物理障碍训练区域。结合不同形态的仙人掌形成的中空和凸起区域,创造出一个完整的运动场馆。
d) Terrain: The overall terrain of the venue's floor is designed to resemble sand dunes. We have abstracted the form of the dunes using trapezoidal standard blocks measuring 450x450 millimeters. By stacking and arranging these standard modules in three dimensions, the ground has been transformed into a basic physical obstacle training area. Combined with the hollow and elevated areas formed by cacti of different forms, a complete sports venue is created.
结语。我们尝试通过研究家庭各成员对运动最本质的需求提炼出几个基础身体机能需求,比如:爬、钻、跳、拉等,以此作为研发和设计拓展的核心。
用建筑构件与空间装置的手法,来解决这些运动机能的需求,研发出既满足机能需求,又具有建筑构件语汇的体系,而不是装饰现成的设备设施。
最终所获得的是独一无二的场景。在这里,运动回归本能需求,在空间任意角落中都可以进行身体的训练,而不是通过一个又一个器械设备,我们希望玩耍、运动可以回归本质,家庭活动可以成就身体的和感官的本能体验。
Wrap up. The design highlights the balance maintained between architecture and toy integration in a family oriented sports environment. Both Climbing Armatures and topographical floor are adapted to fuse the performance of play in their form. Elevating the traditionally accepted strategy of segregated zones arranged in plug-in planning manor, to an ambition to synthesize structural systems to respond to play programs. The integration of play equipment which is not solely visually aligned into the language but also is functionally embedded within Play Apparatus can be achieved through qualities relating to scale, responding to site specific opportunities, and embedding key circulation. Will we believe will enhance the enjoyment for the family and enhance enjoyment.
沙丘地形分析图
建筑方案设计
21.19 万条内容 · 304 人订阅
真美!青砖灰瓦——“徽派风”建筑,现代处理手法!新时代下别样的诗意……
  海丝居艺小镇丨融古汇今的闽北画卷     霍普股份  |  壹众事业部
