土木在线论坛 \ 建筑设计 \ 建筑方案设计 \ 生物医学园区:中国台湾·新竹生物医学园区第三生技大楼
发布于:2024-06-05 10:19:05 来自:建筑设计/建筑方案设计 [复制转发]
中国台湾·新竹生物医学园区第三生技大楼
JJP 建筑规划设计事务所
竹北生物医药园区被群山、农田和空地环绕,形成了优美的研究和孵化环境。该项目是一座11层高的生物医学研究大楼,台湾高速铁路新竹站将位于园区中轴线的两端。
Surrounded by mountains, farmland, and open space, Zhubei Biomedical Park forms a beautiful research and incubation environment. The project, an 11-story biomedical research building, and the Taiwan High-Speed Rail Hsinchu Station will anchor the two ends of the central axis of the park.
该设计基于 “生物核心 ”的概念,探索建筑如何像活体有机体一样根据环境条件激发灵感。该项目为生物技术产业提供了一个创意研究平台,同时融入了可持续绿色能源、技术图像和人文理念,将有机建筑提升到整体意识的高度。
The design is based on the concept of "bio-core“, which explores how architecture can inspire to behave like living organisms in response to environmental conditions. The project provides a creative research platform for the biotechnology industry while incorporating sustainable green energy, technological imagery, and humanistic concepts to elevate organic architecture to a level of holistic consciousness.
建筑体量的集中使得开放空间最大化,并促进了与中央绿化带的连接。建筑的外部设计考虑了环境因素,错开了建筑体量,并通过参数分析,将环境因素转化为有节奏的玻璃窗模式。模块化幕墙单元采用嵌入式玻璃,可在必要时提供遮阳效果,同时向太阳路径倾斜,达到类似于向光性的效果。
The concentration of the building volumes allows for maximum open space and facilitates connection with the central green belt. The exterior design of the building considers the environmental factors to stagger the volumes, and through parametric analysis, translates the response into a rhythmic fenestration pattern. The modular curtain wall units feature recessed glazing that provides shading when necessary while being angled towards the path of the sun, achieving an effect similar to phototropism.
大楼内部以交流和共享为设计理念,研究单元围绕中央中庭布置。每个典型楼层由三个不同大小的单元组成,可以组合成各种配置。这种灵活性得益于独立的用户和材料循环系统以及高效的暖通空调系统。
The interior of the building incorporates communication and sharing as the design concept with the research units organized around a central atrium. Each typical floor consists of three units of different sizes that can be combined to yield various configurations. Such flexibility is supported by separate circulation systems for users and materials, along with an efficient HVAC system.
项目图纸
平面图
平面图
平面图
剖面图
细节图
示意图
示意图
建筑方案设计
21.19 万条内容 · 304 人订阅
Gustav Düsing 密斯奖后中标,改造德国印刷厂为教育中心
Gustav Düsing 和 FAKT 刚刚赢得了在德国锡根设计一个适应性再利用项目的竞赛。继 Gustav Düsing 最近赢得2024年欧盟密斯奖,NAS项目通过一个全面的参与过程得以发展,该过程包括学生、教职员工和社区成员。新建筑学院(NAS)是一个适应性再利用提案,将旧印刷厂改造成一种新型的中央校园。设计旨在作为一个充满活力的城市实体,将学术活动与文化和公共空间相结合。
