土木在线论坛 \ 装修设计 \ 家装设计 \ 热带混凝土住宅,哥斯达黎加Bell Lloc之家
发布于:2024-05-30 15:51:30 来自:装修设计/家装设计 [复制转发]
Studio Saxe受委托设计了一栋位于哥斯达黎加圣特雷莎镇山顶的住宅。鉴于地形极度倾斜,我们决定将卧室的私人区域沉入地下,从而使附带漂浮露台和游泳池的主要生活区域在顶部拥有宽阔的最佳视野。
Studio Saxe was commissioned to design a home perched on the hilltops of the town of Santa Teresa in Costa Rica. Due to the extreme pitch of the terrain, we decided to sink the private areas of bedrooms into the ground and thus allow the main living area to have the best expansive views on top with floating terraces and pool.
▼项目鸟瞰
  ▼街景视角
  ▼漂浮露台和游泳池
  这个项目是如何使用混凝土来实现热带建筑的低成本维护和长期使用寿命的证明,同时项目又不失开放性和与大自然的深度联系。
This project is a testament of how concrete can be used in Tropical Architecture to achieve low maintenance and longevity without loosing openness and deep connections to nature beyond.
▼项目外观
▼与大自然深度联系的混凝土建筑
为了适应地形条件,Studio Saxe决定将房子 “推 ”入地下,从而营造从街上看   是一栋单层住宅的视错觉,只有人走进建筑里才能感受到它的真实尺寸。一系列的混凝土墙对房子起到了遮挡作用,并掩盖了其后经过精心编排的游泳池和海洋的入口。
In order to adapt to the topographic conditions, Studio Saxe decided to “push” the house into the ground thus creating the illusion of a one-story house from the street and only revealing its true size once inside. A series of concrete walls shield the house and disguise what will later become a powerful choreographed entrance reveal of the pool and ocean beyond.
▼适应地形条件的设计
▼从街上看是单层住宅的视错觉
▼入口空间
▼被混凝土墙掩盖的泳池和海洋入口
▼泳池入口
通过将公共生活空间安置在上面,将更具私密性的卧室空间安置在下面,每个触及地面的空间都是更为坚固和封闭的。一条长长的屋顶线保护着房子,并框住了一个悬空于丛林之上的特色入口游泳池。
By keeping the public living spaces above and the more intimate bedrooms below, Studio Saxe used the innate characteristics provided by the site to determine the use of spaces. Every space that touches the ground is more solid and enclosed, and in contrast every space above ground is open and ephemeral. A long overarching roof line protects the house and frames a feature entrance pool that cantilevers over the jungle.
▼公共生活区域概览
▼露台的座椅区
▼被安置在下面的私密性卧室空间
客户希望大部分住宅都是混凝土建造而成的,这样可以延长使用寿命,减少维护,并且在一年中炎热的几个月里收获凉爽。
我们面临的挑战是要在生活区创造开放的空间,运用大跨度的混凝土柱和轻型屋顶,以便在一年中多雨和潮湿的月份进行交叉通风。其结果是,下面的一系列挡土墙容纳了私人空间,上面的梁柱则面向雄伟的海景开放。
The clients of this home were clear from the beginning that they wanted most of the home to be built in concrete for longevity, less maintenance, and thermal mass during the hot months of the year. The challenge was to also create open spaces in the living areas with long span concrete beams and a light roof that allows for cross ventilation during the rainy and humid months of the year. The result is a series of retaining walls below that house private spaces and beams and columns above that open to the majestic ocean view.
▼轻型屋顶下的室内空间
▼混凝土结构室内空间
▼从上层卧室看漂浮露台和海景
▼遵循热带基本生物气候原则的空间
▼平面图
▼立面图
▼剖面图
家装设计
22.34 万条内容 · 392 人订阅
95后新婚夫妻的家,全屋奶油色、弧形元素...超高颜值的轻复古婚房!
对于95后的Z世代来说,不管是吃的穿的还是用的,都要满足“高颜值”这三个字。现在,就连装修这件事也得遵循这个规律,所有的实用属性都得往后排,颜值即正义。 这是95后新婚夫妇的婚房,男主是平面设计师,女主也是设计专业,对于视觉呈现的空间氛围体验有着极高的要求。设计师也希望自己的设计能赋予这个项目独特的设计风格,让这个家具有符合屋主独特的品味和气质。
