土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 有没有人有饲料加工全套设备的平面图、剖视图和预留螺栓图啊?求
发布于:2024-05-28 19:23:28 来自:建筑设计/CAD下载及教程 [复制转发]
有没有人有饲料加工全套设备的平面图、剖视图和预留螺栓图啊?求。
如果是cad的就更好了,谢谢。记得标一下名称
CAD下载及教程
52.09 万条内容 · 690 人订阅
一个框选快速建块并指定层名作为块名同时置入该层的lisp源码
;EECC快速建块并指定层名作为块名同时置入该层(DEFUN C:EECC (/ SS2024 PT1 NN OLDOS)  (SETVAR "cmdecho" 0)  (if (setq SS2024 (SSGET))    (PROGN (setq OLDOS (GETVAR "osmode"))     (SETVAR "osmode" 0)     (setq PT1 (CAR (YY-GET-BOUNDINGBOX2023 SS2024)))      (SETQ NN(cdr (assoc 8 (entget (car (entsel))))));获取图元层名指定层名作为块名同时置入该层     (command "undo")     (command "be")     (command "-block")     (command NN)     (command PT1)     (command SS2024)     (command "")     (command "insert")     (command NN)     (command PT1)     (command "1")     (command "1")     (command "0")     (command "undo")     (command "e")     (SETVAR "osmode" OLDOS)    )  )  ;(Cc_dxfamend (entlast) 8 NN)  ;Cc_dxfamend→图层(程序运行时的最后一个图元)  ;(command (entlast) "layer" NN "")  (command "_chprop" (entlast) "" "layer" NN "") ;改变最后一个图元图层  (SETVAR "cmdecho" 1)  (PRINC));YY-GET-BOUNDINGBOX2023最大包围盒(DEFUN YY-GET-BOUNDINGBOX2023       (SS / I ENT OBJ PTA PTB DWCORN UPCORN PTLIST X Y)  (setq I 0)  (setq DWCORN nil)  (setq UPCORN nil)  (REPEAT (SSLENGTH SS)    (setq ENT (SSNAME SS I))    (setq OBJ (vlax-ename->vla-object ENT))    (vla-GetBoundingBox OBJ 39;PTA 39;PTB)    (setq DWCORN (CONS (vlax-safearray->list PTA) DWCORN))    (setq UPCORN (CONS (vlax-safearray->list PTB) UPCORN))    (setq I (1+ I))  )  (setq PTLIST (APPEND DWCORN UPCORN))  (setq X (MAPCAR 39;CAR PTLIST))  (setq Y (MAPCAR 39;CADR PTLIST))  (LIST  (LIST (APPLY 39;MIN X) (APPLY 39;MIN Y))  (LIST (APPLY 39;MAX X) (APPLY 39;MAX Y))  ))
